$200 to spend on mods
Old Aug 20, 2004
iluvmycsx
Guest
Posts: n/a
i am thinking of doing some mods
not to sure though???
intake
exhast
grille
on a limited budget
Old Aug 20, 2004
JDMVTECB20's Avatar
JDMVTECB20 is an unknown quantity at this point
Intake
Old Aug 20, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
If your on a limited budget,,,,I would say save your money. All of those items won't do crap for a honda except for making it look better, if that. I gave up on all that crap, and i think it's a waste of money. Just my opinion though.
Old Aug 21, 2004
vtec_concept's Avatar
vtec_concept is an unknown quantity at this point
Tell us about your EL..
what tranny does it have? is it an auto? or 5-speed...
then we can figure out from there
Old Aug 21, 2004
TeLLy's Avatar
Yes, it's an Acura EL
intake
exhast
grille
on a limited budget
$200 doesn't get you a lot I'm afraid, BUT here's my take on it:
It will get you a BC front upper grille ($180 plus shipping) but you have to get it painted.
It will get you an axleback exhaust - all sound, no performance...I have it, looks and sounds good, but realize it's all for looks and sound. Frankly most exhausts don't get you much anyway on a D17 motor.
It will get you a generic intake with some loot to spare
It will get you a front upper strut bar and a used 19mm RSX rear sway bar with bushings.
It will get you a DC5-R 22mm rear sway bar with bushings...add a few more bucks for Grey's endlinks though - you WILL snap your stock ones
It will get you a decent set of used Neuspeed or Goldline springs (H&R is too soft for the EL rear and will sag)
It will get you a decent used header
It will get you a decent CD/mp3 deck
It will get you a decent set of used component speakers with crossovers
It will get you a set of pedals and a shift ****, with enough for a nice shift boot too (assuming you drive a 5-speed)
It will get you a good tint job
It will get you a used decent brand (small) sub and amp combo
It will get you enough supplies to paint your interior components (and pay for someone's services to paint them)
It will get you a center console LED mod (tee hee)
It will get you an aftermarket gauge and a pod/gauge cup to hold it in
It will get you underbody neons
It will get you a front lip/rear lip/used side skirts (painting extra)
It depends what you want to do really. IMHO you shouldn't look at it like "I have this much money, what can I buy for my car". That kind of thinking leaves cars riced out with no theme or direction for modification. I speak from horrible horrible experience. Try to look at it as "What do I really really really want for this car, and how much more do I have to add to this $200 to make it happen?" You'll find yourself saving that money even more, then one day BLAMMO, something really fun like a full molded body kit, big system, big rims and tires, turbo/swap, the list goes on. Like everyone says, you gotta pay to play in the import tuning/modding world.
OK that all said, I'd personally grab a set of used springs (save money for aftermarket shocks in the near future) or the tie bar/sway bar combo - the former will improve appearance and handling and with the latter you'll feel the difference right away in improved handling and chassis stiffness. Failing that, some audio system upgrades may also be nice.
Old Aug 21, 2004
iluvmycsx
Guest
Posts: n/a
wow telly you do know alot
i bought a vibrant power 1 strut bar (havnt paid for it yet and it cant be ordered till monday ) was thinking of getting
the rear one too
are they any good???
Old Aug 21, 2004
TeLLy's Avatar
Not bad. You'll feel the difference as soon as you put it on, I guarantee. Generally most people don't push their cars hard enough to tell the difference between a brand name (ie Neuspeed) and a generic (ie Vibrant) strut bar too. Keep in mind though no cold air intake will fit well with a generic strut bar. Only the DC Sports and Neuspeed bars clear intake piping.
I had a rear upper strut bar which I was forced to sell because the rear mounting bolts on my Hayames weren't long enough to put the strut bar mounting brackets then the nuts back on. Boo-urns. May buy another one soon and take a chance.
And now off to bed.
Old Aug 21, 2004
iluvmycsx
Guest
Posts: n/a
thanks for your help
its really appreated
Old Aug 23, 2004
iluvmycsx
Guest
Posts: n/a
i have bought the strut bar it shoud be here on tuesday (hopefully)$60 vibrant power1
looking for a used rear rsx sway bar locally
does it make a diff if type s or not?
should i upgrade endlinks??
diy is it basically the same as this one
http://www.7thgencivic.com/forums/sh...d.php?t=155274
Old Aug 24, 2004
TeLLy's Avatar
I think all the RSX bars except the DC5R are 19mm.
I recommend upgrading endlinks, cause the stock EL ones are crap to remove and you might damage them removing. Talk to Grey, he makes a wicked set.
Old Aug 24, 2004
iluvmycsx
Guest
Posts: n/a
i was going to pick up greys endlinks
Old Aug 24, 2004
TeLLy's Avatar
Do it. One of the best mods I've gotten for my suspension.
Old Aug 24, 2004
iluvmycsx
Guest
Posts: n/a
do you have to measure to fit in the endlinks(greys)
or are the made just for civic/el??
Old Aug 24, 2004
TeLLy's Avatar
They're made for our cars specifically, although they will also fit DC and EP chassis (RSX and SiR respective).
Old Aug 25, 2004
iluvmycsx
Guest
Posts: n/a
ok thanks
installed the strut bar easy bolt on
noticed the improvement in the steering
thanks again for the advice
Old Aug 25, 2004
TeLLy's Avatar
If you one day feel that your handling isn't where it should be, take that strut bar off and drive around for a day. You'll come running back and telling it "Let's never be apart again".
Old Aug 25, 2004
iluvmycsx
Guest
Posts: n/a
here is a pic of what it looks like installed
Old Aug 25, 2004
TeLLy's Avatar
Good job. Now for your next mod....CLEAN that engine bay!
Old Aug 26, 2004
iluvmycsx
Guest
Posts: n/a
it been raining here all week havent had much time to clean the car it been a week and a half since i last cleaned it so i know it needs it badly
Old Aug 26, 2004
TeLLy's Avatar
Just back the car onto the driveway, pop the hood, and go back inside, LOL.
Just kidding, don't do that. Not that it matters much anyway, our engine bay is so wide open driving in the rain, water gets in the wheelwells right up to the hood liner.
Old Aug 26, 2004
iluvmycsx
Guest
Posts: n/a
is there any way to fix this problem??
or is it that way cause it helps cool the engine
Old Aug 28, 2004
TeLLy's Avatar
I don't really see any way or need to fix the problem. I've been driving around with a cold air intake and various electrical implements in the engine bay, and no problems with any of them.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Munzy
21
Oct 7, 2015 07:48 AM
Jrosa
Sep 14, 2015 08:24 PM
