Disable VALET Mode
Old Jul 27, 2004
GohanChr1s's Avatar
GohanChr1s is an unknown quantity at this point
Disable VALET Mode
can you guys help me disable my valet mode for my car. the car locks when i click on the lock button, but it no longer beeps and the headlights don't light up. its an 02 civic ex. thanks
Old Jul 27, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
Did you press it twice?
Old Jul 27, 2004
GohanChr1s's Avatar
yes i have, actuallly this problem has been there for a while now...
Old Jul 27, 2004
jttegx's Avatar
OMNES AD UNUM
did you check your owners manual?
i never knew you can change it to valet mode =|
Old Jul 27, 2004
Master's Avatar
Banned by Admin
If you have a remote just give the valet the remote.
Old Jul 27, 2004
arcalan's Avatar
arcalan is an unknown quantity at this point
owners manual.....will help
Old Jul 27, 2004
bfitz's Avatar
bfitz is an unknown quantity at this point
Get in your car. Close the door. Lock and unlock the doors with the door switch. Insert your key into the ignition and then remove it 5 times in rapid succession. Lock and unlock you doors again with the switch. Then try your remote. That does it on my '03. Or maybe it's unlock and then lock then do the key thing and unlock and lock again. Anyway, try both, one of them should work.
-Fitz
Old Jul 27, 2004
Master's Avatar
Banned by Admin
Why did u post this in two different forums? Come on put it in one forum if it is wrong it will get moved but you don't need to post in two different forums!
Old Jul 27, 2004
GohanChr1s's Avatar
thanks BFitz, worked perfectly as you said
Old Apr 24, 2018
bradix's Avatar
bradix is an unknown quantity at this point
Re: Disable VALET Mode
-Fitz
i do have the same problem with my 04 civic recently. would this fix my problem to? i recently lost the horn sound after i lock with the remote 2 times. the horn should supposed to honk with flashing lights... am i also in valet mode?
tnx...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Luluharp
Sep 27, 2015 11:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
