104 octane
Old Jul 21, 2004
detroitbeats's Avatar
detroitbeats is an unknown quantity at this point
Question 104 octane
i can get 104 for my 03 si .will it do any damage to use? i have no idea.please help if u know .thanks
Old Jul 21, 2004
acjones20's Avatar
acjones20 is an unknown quantity at this point
eh, if you want to waste money and get crappy performace go ahead (unless you did some crazy stuff w/ that hondata) just use pump gas. 104 is for supras
Old Jul 21, 2004
civic01vtec's Avatar
don't waste your money unless you have a heavy heavy motor build or f/i. Even then it is a waste of money.
Old Jul 21, 2004
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
I'm pretty sure that it's not too bad to run the odd time.. Just as a little treat or something.. But I think it has potential to do damage.. At least that's what I've heard.. Something about the fuel being hotter or something and on stock internals it's probably not so hot. This is just what I hear.. Try to do a search if you haven't already because I think I remember reading about higher octane for our cars!
Old Jul 21, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
It'll hurt performance unless your built big time, and its a waste of money.
Old Jul 22, 2004
doubledeuce2k2's Avatar
it'll be great after you swap to a k20a. until then i would laugh at you and throw pudding at your car.
Old Jul 22, 2004
DVnAFI's Avatar
Tiene tremendo...CULO!
DVnAFI is an unknown quantity at this point
ohh!! 103! that would go great with my Audi. hmm, but all they have here is 91
Old Jul 22, 2004
jttegx's Avatar
OMNES AD UNUM
holy ****, 104? isn't that like nascar fuel or something?
and i thought 94 octance was the best for built cars
is it possible to get something over 91 locally? not for the vic but for other crazy modded cars. at like 76 or chevron or something?
Old Jul 22, 2004
joski's Avatar
They sell 114 octane or something like that in Stratford (a town around here).. I had to look a couple times.. They were advertising all their 100+ octane on their sign!
Old Jul 22, 2004
HondaLuver's Avatar
Its a celebration bitches!
yea it would be good for ur audi... its probably 10 bucks a gallon, over here at a 76 in pasadena they sell 100 octane for about 5.50 a gallon pump gass
Old Jul 22, 2004
dalaw's Avatar
Bone Stock!
those 104 octane are for fighter jets and stuff
Old Jul 22, 2004
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
104 Octane would be a waste of time and money. Octane is the ability of your engine to burn the fuel. Your stock Si can't compress and fire the fuel so you will be wasting the extra fuel. Thats why when your car starts to "ping", its caused by too low of an octane. The fuel will actually start to fire before the piston is TDC (the height of its compression). I'm sure theres more to the theory then what I've said but that should be the basics.
Old Jul 22, 2004
Jodster's Avatar
Post Whore General
the K20A3 is designed to run on 87 octane. If you where boosted running over 10psi than high octane would help make some high numbers on the dyno. Otherwise don't bother with the higher octane. I run 93 in my Type S.
You can buy 94 from one or two of the gas stations around my area. Otherwise its 93.
Old Jul 22, 2004
fighter jets and such use different fuel, like jp8. it's completely different from gasoline, and really not much like diesel either. you could light a match and toss it in a bucket of jp8 and nothing would happen.
i can find 94 at sunoco, they charge 10cents more than premium 92. but bp/amoco has 93, thats the best i can find normally.
Old Jul 22, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
danscreations boss has to put 102 inhis Evo8... only avail at sonoco around here
Old Jul 22, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I went racing last night and was on empty so I had to buy 100 Octane (it was the lowest grade
they sell)
JUst 1 gallon made me run slower by 4/10ths ... I don't think it helps...I usually run on 89.
Oh yeah some of the higher octanes 110+ are leaded too and will fukc up your catylitc converter.
Old Jul 22, 2004
Zzyzx's Avatar
Autocross Junky
From the wonderfull site "How Stuff works"
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
Conclusion
Using an octane higher then what your car can use is a waste because the engine simply doesnt make High enough compression to use that gas properly. So, If you were running FI or had altered the compression ratio on your car then shure you could take advantage of 104 Octane gas. as it stands on a Relitivly stock K20, 92 is the minimum, if you want a little extra spunk go with 100, but 104 is a bit much.
Old Jul 22, 2004
jttegx's Avatar
OMNES AD UNUM
so would pumping 91 at my local 76 make me a fool?
hmm maybe ill go back to 89
Old Jul 22, 2004
Zzyzx's Avatar
Autocross Junky
With the D17, you could probably get a little extra performance by running 89 Vs 87, but we dont make enough compression to properly use 91+...
On a side note, I use 87 exclusivly. and I autocross alot.
Old Jul 22, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
on a n/a civic high octane would be
if you were boostin that'd be a different story.
Old Jul 23, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
I beg to differ. Ill end it there.
Old Jul 23, 2004
ctx66's Avatar
with which reply, mine or one of theirs?
Old Jul 23, 2004
allmotor's Avatar
nor cal 7thgens
unless u have some high compression plz dont do it
shaejb15
Jul 27, 2015 03:48 PM
fvckbg
Jul 7, 2015 07:08 PM
rushcivic
Aug 26, 2002 01:07 PM
crazyjetskier
May 17, 2002 07:02 PM
FLiPpIeS
Apr 15, 2002 12:14 AM
