Grounding point --> Headlight?
Old Apr 14, 2004
zen_master's Avatar
Arrow Grounding point --> Headlight?
Hi guys!
I got a question for those of you who got lot'sa of grounding point no ur civic..
What is the best grounding point to eliminate the slight dimming on your headlight when you turn on the AC/Heater?
Other than that, can you recommend one other grounding point that's important and easy to install?
I probably only want to install two...at most......easiest.....especially that #!@*$ point which caused the dimming on my headlight...
THANX!
Old Apr 14, 2004
I have a crazy ground system with voltage regulator and the lights still dim slightly. The most important ground is the stock batery to chassis. Second one you should do is the thermostat housing that connects to the chassis (stock silver wire). But connect it directly to the battery.
Old Apr 15, 2004
zen_master's Avatar
aw man...
i thought that it's gonna totally fix the dim headlight..
well...
so, hows this..
connect battery negative to chassis with new grounding cable...
connect from engine to chassis with new grounding cable (the silver one, behind the bumper)
then, from the chassis, connect to the negative battery again..
how's that?
Old Apr 15, 2004
It's better to send the grounding cable directly back to the negative terminal on the battery.
intensity
May 12, 2015 10:43 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
McD
Apr 22, 2015 05:28 PM
civic_gt
Apr 19, 2015 08:15 AM
