Down shifting or neutral braking?
Old Jan 19, 2004
  #31
Philip's Avatar
Philip is an unknown quantity at this point
on a bike i would always downshift...by in our Civics ???
Old Jan 19, 2004
  #32
Zzyzx's Avatar
Autocross Junky
Originally posted by trashguy
AutoX and anyr acing is stopping and aclerating fast as the car can handle why maintaing smoothness :-D
Yup smoothness is the key, and that means getting your down shifts perfect (Especially for mid corner down shifts) and that takes a lot of seat time. so I down shift all the way down to 1st on and off the track.
Old Jan 19, 2004
  #33
trashguy's Avatar
trashguy is an unknown quantity at this point
yea good practice... Its all (this sound bad) hoe you feel it in your butt...
Old Jan 19, 2004
  #34
pheaton's Avatar
A descendant of 2k1civic.com
I often times just neutral brake. I know how to and occassionaly downshift and brake. It allows me to slow down faster while not having to brake hard and send my passangers flying by the sudden jolt of the tires getting stopped. Do depending on the situation, I don't do either all the time.
Old Jan 19, 2004
  #35
born2xLr8's Avatar
I think this thread is done...it's your choice whether you want to shift into neutral and brake or downshift. Like pheaton, I do both.
Old Jan 21, 2004
  #36
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
downshifting. How can it be so hard? Puts a lot less stress on your brakes too.
Old Mar 21, 2005
  #37
1PHATSI's Avatar
proudpinoy
1PHATSI is an unknown quantity at this point
i do the same thing. clutch - neutral - brake..
Old Mar 21, 2005
  #38
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
^^^ Wrong way to drive, and nice job waking the dead.
Old Mar 21, 2005
  #39
1PHATSI's Avatar
proudpinoy
same thing man sorry for waking this thread up.. brake clutch...clutch brake
Old Mar 22, 2005
  #40
sw388integra's Avatar
You can't mess up your drivetrain if you know how to downshift. Its just the reverse of upshifting. Clutch, shift, gas to match revs, let off the clutch, then take your foot off the gas and let momentum slow you down. Won't do anything bad if you do it right, use the engines momentum with the brakes and you'll slow down smoother and waste less brakes. Now, in short stops and panics, by all means use just the brakes and kick it in neutral, but if you've got a light you know is red, just downshift and coast. Go down on the 5's....
4th at 55, 3rd at 45, 2nd about 35 (go a little less)... should drop you right about 4K RPM.
what he said..
Old Mar 22, 2005
  #41
diskreet's Avatar
the auto trannies that come with our civics suck and should not be put into neutral or anything while driving cause they are too weak. other cars yes its ok but does absolutly nothing except wear the auto trannies clutches. thats the only gain...more garage time, that and the engine will run for 100 more miles its whole life. but yeah dont bother.
Old Mar 22, 2005
  #42
indoyum's Avatar
indoyum is an unknown quantity at this point
mee noo liek dees threaad. Everyone seems to stick to their own opinions even after discussing about this for 3 months. I am in favor for downshifting, even the honda manual says that downshifiting to help stop your car is recommended to save the brakes in the long run. I think if downshifiting was bad in the longrun, the honda manual would say not to do that. BUT, then again, why do I even bother, its not gonna change anyone's minds.
Old Mar 22, 2005
  #43
chicohonda02's Avatar
Since 2002 Baby!
i down shift, but never thought it would use up more gas. hmmm... intereresting
Old Mar 22, 2005
  #44
diskreet's Avatar
downshift in manual:
less brake wear
more fuel
downshift in auto:
less brake wear
more fuel
kills tranny slowly
Old Mar 22, 2005
  #45
gsrchad's Avatar
gsrchad is an unknown quantity at this point
downshifting and slipping the clutch in doesnt waste more gas unless you press the gas to match revs. otherwise there is no more fuel going into your motor than it is sitting at a 700rpm idle. and downshifting on a 55 or 35 mph road is pointless and adds clutch and tranny wear. just as shifting does... so why add clutch and tranny wear when clowing down is what the brakes are for.
seems a waste and added unwanted stress to the car. but if your racing then yes, becasue racing is adding WAnted stress and you want to win right. otherwise, if slowing down for a stop light, just use the brakes like there designed for....
Old Mar 23, 2005
  #46
nindoo's Avatar
Why is my vagina bleeding?
Oh snap son!
Overall you have to be smooth, denfinately, when your pushing your car hard you don't want to slip the clutch, not only from the point of few of damaging your clutch but also from a safety point of view. You will see that you will loose balance and smoothness so your car wont behave predictabily which is very dangerous when your going fast.
I wouldn't use the compression of the engine of the car to slow it down. For example I wont downshift to slow down the car, I'll down shift to stay in a certain rpm range. Our car engines are designed to accelerate they aren't built the same way as truck engines.
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
