Top Speed
Old Dec 16, 2003
  #31
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
naw i got a 5 speed lx.. and it won't go past 120.. i think after a certain rpm level.. it won't go any further. therefore u have to have more horsepower, to acheve a faster speed, before u reach 5000 rpm in 5th gear..
Old Dec 17, 2003
  #32
RiceRiley's Avatar
RiceRiley is an unknown quantity at this point
My 01 coupe hits about 114 then the governor limiter stops it from going any further. Does anyone know how you can get this removed or am I SOL
Old Dec 17, 2003
  #33
i asked that same question... and u can't remove the governer or anything.. it's stuck at that speed.
Old Dec 17, 2003
  #34
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Just so we can be on the same page, what exactly does it do when it "hits the governer" ?
Old Dec 17, 2003
  #35
AudioQuest's Avatar
AudioQuest is an unknown quantity at this point
Honestly, why would you want to go those speeds in a Civic? If you hit something, you're DEAD instantly. Think about it.
Old Dec 17, 2003
  #36
SPORT2087's Avatar
SPORT2087 is an unknown quantity at this point
i have had my car up to 134 mph racing a ford escort it was a 91..... i still had a lot of pedal left......... i think the car still would go faster but it gets a little loose feeling
Old Dec 17, 2003
  #37
pothole's Avatar
pothole is an unknown quantity at this point
I had mine 130mph on the bottle
Old Dec 17, 2003
  #38
SilverVSpec02's Avatar
SilverVSpec02 is an unknown quantity at this point
Originally posted by nastinupe1
I got my 94 EX Coupe 5 Speed with no mods up to around 132 MPH. I was scared shitless though. 14 inch tires suck.
an un moded civic cannot reach those speeds, especialy an ex- governed at 118/119 mph
thats impossible, my 02 spec-v does 138mph top speed in the cold with AEM cold air intake and relocated knock sensor- so you're gonna tell me that you civic is jsut as fast as my spec-v, im sorry but that is impossible
Old Dec 17, 2003
  #39
BTW civic's are drag limited/ governed they cannot reach those speeds unless you 1, increase horsepower by like 25hp or more, and reduce the drag, 127hp stock is not capable of doing that unless you mod/ remove govenor
Old Dec 17, 2003
  #40
what is a civic spec-v and where can i get it???
and to answer the other question when the governer kicks in... you will feel it instantly.. the power to the engine shuts off, and you will fell youself slow down to about 115-117.... it usually kicks in in 5th gear at 5,000 rpms...
Old Dec 17, 2003
  #41
RiceRiley's Avatar
It kinda scared me when I found out. I was testing what speed I can get to and when I reached 114 it felt like the engine shut off until it dropped to about 110. I thought something went wrong but then I tried it again and it did the same thing I realized it was the limiter. I asked a friend and he said it was the limiter. He says there is a way to re-program it.
Old Dec 17, 2003
  #42
TMRakip's Avatar
TMRakip is an unknown quantity at this point
170 MPH
Old Dec 17, 2003
  #43
well tell me how can it be re-programed
Old Dec 17, 2003
  #44
Zzyzx's Avatar
Autocross Junky
Not nessisarily, the civic would just take longer to reach those speeds. so even if the 2 cars have the same top speed one just gets there faster.....
also, by what is it governed by??? the MPH?? That couldnt be because I had mine up to +120 (according to the speedo) and I was running 205/40-17s (4.18% smaller) so my corrected speed was aproximatly 114, but the car thought I was doing 120.... So whats the deal?
Old Dec 17, 2003
  #45
civics are mostly drag limited- my friend has gotten one up to 122 with no passengers, but he recorded it. anyways, since the civic is drag limited you would need copious ammounts of hp to compensate for it. plus all speedo's at the speed have about a 4% loos jsut like yours, so a corrected speed for the civic is about 125ish. also, some speedo's my spec-v and civic included have to be recailibrated due to change in tire size, new rims, ect.. if you dont do this you wont get an accurate reading. my speed was measured by a friend of mine who used his police radar gun. thats the only true way to measure your speed
the govenor works by rpm's not MPH. most govenors kick in around the redline, i recall someone metnioning at 5,000 RPMS on here. im not sure if thats true but, when the govenor or rev limiter kicks in there is an instant loss of power and the engins shut itself down until a pre-determined speed is reached. usualy 155.
i apologize for the type-o, there is no civic spec-v. lol
Old Dec 18, 2003
  #46
RiceRiley's Avatar
Well if I knew how to re-program it I wold tell you. See, the friend that told me this likes to talk and thinks he knows everything and maybe he just made it up. Im just going to have to figure it out myself if it can be re-programed or not. If i get any info i'll get back to you.
Old Dec 18, 2003
  #47
civic01vtec's Avatar
Re: Top Speed
Originally posted by JetBlu01
Yo I got an '01 Civic EX and I was just wondering what were yall top speeds...I've gotten mine up to 125 mph...well I do it all the time actually.
Old Dec 19, 2003
  #48
mclean987's Avatar
mclean987 is an unknown quantity at this point
went to 140mph today
Old Dec 20, 2003
  #49
Lucid484's Avatar
Lucid484 is an unknown quantity at this point
110 mph 2001 LX Sedan (Stock)
Did this at 3am last night on the mass pike comming home from boston! And the governor kick in the second my car hit 110 =(
Old Dec 21, 2003
  #50
dan_11477's Avatar
dan_11477 is an unknown quantity at this point
What's this rubbish about 5,000 rpm limiter? Max power for these engines is at 6,300 rpm and my rev limiter kicks in at 7,000 rpm. Why would honda limit to 5,000 when they are famed for their fantastic reving engines?
Max torque on the other hand peaks at 4,800 rpm.
Where did the information come from that there's a speed limiter? Mine just seems to naturally run out of oomph at around 138mph (speedo reading) and yes i'm aware of inacuracies and I am running totally stock.
As the top speed occurs after the peak power point in 5th gear you can't expect it to just keep getting faster.
It's not how fast you drive but how you drive fast that matters and although coupes aren't the fastest cars in the world the type R only goes to 146mph ish (only 10mph diff) and i would never get insurance for it.
Old Dec 21, 2003
  #51
dan_11477's Avatar
lucid484: only 110? you need to change otta 4th and into 5th!
Old Dec 21, 2003
  #52
Old Dec 21, 2003
  #53
Lucid484's Avatar
i'm driving an auto sedan with me and 2 other passengers one of which weighs 200lbs....not saying that i couldnt go faster but it took like 15sec to climb from 100-110 and my friends car was about 500yards ahead of me and they tapped their brakes so i thought they were signaling for cops,so backed the hell off...I'm sure it can go faster but I have no need to,just curious if it would hit that speed.
Old Dec 21, 2003
  #54
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
thats common sense having some fat basterd in your car will slow it down, just think of this how fast can you swim with a fat person strapped to your back????? its physics adding wieght will force your car to work harder to accelerate.
Old Dec 21, 2003
  #55
CarbonFly's Avatar
Someone had their shop put his car up on a dyno and they did something to his 7thgen. He as able to get upto 183mph i think. He posted photos of it, but I cant seem to find them right now.
Old Dec 22, 2003
  #56
what the hell are yall talking about?? what kind of "special" civic do u have. 140 mph, 183 mph... come on now... there is not a stock civic in the world reaching thoes speeds, on factory tires, suspension, ect... all that is nonsence, and speculation.
Old Dec 22, 2003
  #57
zachgeyer's Avatar
Originally posted by deciuss
i can only get mine to 100 weard...
i thought the same this about mine but it sitfs at 100mph .put it in D2 and it will go like 120 are more i got mine to like 125mph and it was like at 5000rpms.
Old Dec 22, 2003
  #58
WD40's Avatar
WD40 is an unknown quantity at this point
2002 EX Coupe, Manual.
Old Dec 22, 2003
  #59
XxSoVeReiGNxX's Avatar
I can get my automatic trans civic passed 105 easy (when the highway is empty). But then I lose my *****. It gives me a wrong feeling when I'm going too fast in a Civic; it doesn't prove anything really.
Old Dec 22, 2003
  #60
gizcivic's Avatar
gizcivic is an unknown quantity at this point
01 lx sedan 120 racing an old talon with turbo
putting something on to ecu see if it will change i will let you guys know if it does
