hmmm... Carbon Fiber..
Old Oct 26, 2003
ImPulse's Avatar
Arrow hmmm... Carbon Fiber..
Of course its a lambo..
Old Oct 26, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
sweet.....
Old Oct 26, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee e
Old Oct 26, 2003
abmerop18's Avatar
Jam out with your clam out.
nice.
Old Oct 26, 2003
Samari's Avatar
very nice
Old Oct 26, 2003
Darkside9360's Avatar
Darkside9360 is an unknown quantity at this point
ughhh, never liked exotic cars, i respect them for what they are... But i wouldnt wanna own one, im 17 and i have driven a ferrari (only got to drive it for like 15 min but still) and i hated it, but most people will never drive one and they dont know how uncomfortable they are.
Old Oct 26, 2003
Shambler's Avatar
I'm an idiot.
Shambler is an unknown quantity at this point
I guess it tends to get uncomfortable when goin 160+ and not even pushing the car...
Old Oct 26, 2003
7thGenerasianCivic's Avatar
Yea but it's good eye candy.
Old Oct 26, 2003
jesus christ i love your signature!!!!!!!!!!! who is that in the corner?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?! ?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?! ?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?
Old Oct 26, 2003
X-R8ED's Avatar
X-R8ED is an unknown quantity at this point
The Ferrari ENZO has an all carbon fiber chassis,carbon fiber ceramic composite brake pads,carbon fiber valve cover and no power windows
Old Oct 26, 2003
X-R8ED's Avatar
yellow
Old Oct 26, 2003
ImPulse's Avatar
lol... I like the new NSX better for some reason =\
Old Oct 26, 2003
X-R8ED's Avatar
$6000 carbon-ceramic brake pads and a $24,000 set of similarly constructed brake rotors
Old Oct 26, 2003
X-R8ED's Avatar
"Inside, the charcoal-hued cave of bare carbon fiber is all business. Sparse rubber floormats are the only covering over the glistening cured-resin skin of the carbon-fiber tub. The taut, French-seamed leather upholsters only the front of the bare carbon-fiber buckets, and the dashboard, also carbon fiber, has the look of being only half-finished with fist-size gaps. You can see air-vent ducts snaking in the shadows and the various joints and splines of the steering column. With the Enzo, the engineering is purposefully laid bare for all to ogle."
Car & Driver
Old Oct 26, 2003
X-R8ED's Avatar
FERRARI ENZO FERRARI
Vehicle type: mid-engine, rear-wheel-drive, 2-passenger, 2-door coupe
Price as tested: $659,430
Price and option breakdown: base Ferrari Enzo Ferrari (includes $8400 freight and $7700 gas-guzzler tax), $659,430
Major standard accessories: power steering, A/C, tilting and telescoping steering wheel, fitted luggage
Sound system: none
ENGINE
Type: V-12, aluminum block and heads
Bore x stroke: 3.62 x 2.96 in, 92.0 x 75.2mm
Displacement: 366 cu in, 5999cc
Compression ratio: 11.2:1
Engine-control system: Bosch Motronic ME7.1.1 with port fuel injection
Emissions controls: 3-way catalytic converter, feedback air-fuel-ratio control
Valve gear: belt-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timing
Power: (SAE net) 650 bhp @ 7800 rpm
Torque: (SAE net) 485 lb-ft @ 5500 rpm
Redline: 8000 rpm
DRIVETRAIN
Transmission: 6-speed manual with automatic shifting and clutch
Final-drive ratio: 4.10:1, limited slip
Gear ... Ratio ... Mph/1000 rpm ... Max. speed in gears
I ... 3.15 ... 6.3 ... 50 mph (8000 rpm)
II ... 2.18 ... 9.1 ... 73 mph (8000 rpm)
III ... 1.57 ... 12.6 ... 101 mph (8000 rpm)
IV ... 1.19 ... 16.7 ... 134 mph (8000 rpm)
V ... 0.94 ... 21.2 ... 169 mph (8000 rpm)
VI ... 0.76 ... 26.1 ... 209 mph (8000 rpm)
DIMENSIONS AND CAPACITIES
Wheelbase: 104.3 in
Track, F/R: 65.4/65.0 in
Length: 185.1 in
Width: 80.1 in
Height: 45.2 in
Ground clearance: 3.9 in
Curb weight: 3262 lb
Weight distribution, F/R: 43.9/56.1%
Fuel capacity: 29.1 gal
Oil capacity: 12.2 qt
Water capacity: 20.9 qt
CHASSIS/BODY
Type: unit construction, carbon-fiber-reinforced plastic tub bonded to aluminum-honeycomb panels with 1 crossmember
Body material: carbon-fiber-reinforced plastic
INTERIOR
SAE volume, front seat: 47 cu ft
luggage space: 2 cu ft
Front seats: bucket
Seat adjustments: fore and aft, seatback angle
Restraint systems, front: manual 3-point belts, driver and passenger airbags
General comfort: poor fair good excellent
Fore-and-aft support: poor fair good excellent
Lateral support: poor fair good excellent
SUSPENSION
F: ind; unequal-length control arms; pushrod-actuated coil-shock units with 2-position cockpit-adjustable, electronically controlled shock absorbers; anti-roll bar
R: ind; unequal-length control arms; pushrod-actuated coil-shock units with 2-position cockpit-adjustable, electronically controlled shock absorbers; anti-roll bar
STEERING
Type: rack-and-pinion, power-assisted
Turns lock-to-lock: 2.6
Turning circle curb-to-curb: 40.4 ft
BRAKES F: 15.0 x 1.3-in vented, cross-drilled disc
R: 15.0 x 1.3-in vented, cross-drilled disc
Power assist: vacuum with anti-lock control
WHEELS AND TIRES
Wheel size F: 9.0 x 19 in, R: 13.0 x 19 in
Wheel type: forged aluminum with center-lock hub
Tires: Bridgestone Potenza RE050A Scuderia;
F: 245/35ZR-19, R: 345/35ZR-19
Test inflation pressures, F/R 32/32 ps
Old Oct 26, 2003
Blur3737's Avatar
Blur3737 is an unknown quantity at this point
mmm
Old Oct 26, 2003
civic-king's Avatar
Sound system: none
ENGINE
Redline: 8000 rpm
DRIVETRAIN
Wheelbase: 104.3 in
Length: 185.1 in
Width: 80.1 in
Height: 45.2 in
CHASSIS/BODY
INTERIOR
Front seats: bucket
SUSPENSION
STEERING
WHEELS AND TIRES
you forgot to add the gas millage:
8 miles to the gallon.
whoo-hoo.
29 gallon tank?
what does that mean...? 232 miles on a tank, if you don't push it too hard. since it's a enzo, you probibly will, so like 200-220 miles to the tank? then it's almost $60 to fill it back up!!
in a week, i'd spend almost $90 on gas? my civic i spend like $30 max.
but i guess it's easer to get a hot date in the enzo. you get what you pay for....
Old Oct 26, 2003
ImPulse's Avatar
lol... man.. I spend like 40$/week on gas =\
Old Oct 26, 2003
Hawk's Avatar
You boost, I-VTEC
i saw a Murcilago (sp?) yesterday in the rich section of my area. Me and my friend were in aw. Its not very often you see a car like that in person. It's a truely gorgeous car in person.
Old Oct 26, 2003
nme3's Avatar
JDM wannabe
DAMN!!!
Old Oct 27, 2003
X-R8ED's Avatar
Its $900us for an oil change.LOL
Old Oct 27, 2003
Jodster's Avatar
Post Whore General
MMMMMMM CF MMMMMMMM
Old Oct 27, 2003
WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Old Oct 27, 2003
Dr5D's Avatar
yea, I used to have one of those, but traded it in for my civic...
lease:
Old Oct 27, 2003
WD40's Avatar
WD40 is an unknown quantity at this point
I was at Wal Mart the other day and I saw a U-haul truck going through the parking lot towing a Lambo Diablo on a trailer. Kind of a strange combination.
Old Oct 27, 2003
cdmx's Avatar
all they are, are freakin race cars...
I really wouldn't want to own one...I really wouldn't be able to keep it up.
Old Oct 27, 2003
civic-king's Avatar
rich people stay rich by being cheap....
Old Oct 27, 2003
KeNsHiN's Avatar
LEVA
Price as tested: $659,430! f u c k !
Old Oct 27, 2003
KeNsHiN's Avatar
LEVA
whoo-hoo.
29 gallon tank?
bro..if you could aford a enzo then 90 a week would be **** to you lol
Old Oct 27, 2003
Sc0o73r's Avatar
Sc0o73r is an unknown quantity at this point
damn straight
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
nickeynick
Apr 27, 2015 01:23 PM
RegulatorRacing
Apr 12, 2002 04:22 AM
