hows ur clutch?
Old Oct 6, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
hows ur clutch?
i drove an rsx today.. and i noticed that the clutch pedal was significantly stiffer than on my civic...
so... my question to you is, is your clutch pedal buttery soft? or does it take some effort to press it?
Old Oct 6, 2003
abmerop18's Avatar
Jam out with your clam out.
it is extremely soft, but i dont have much to compare it to other than my older 91 civic, which was still pretty soft.
Old Oct 6, 2003
i kinda like mine soft... i drove my friend's 20th anniversary 1.8T GTI... stiff clutch, but nice to drive... when i came back to vegas i drove my civic.. and, like i said, i kinda like my soft clutch.. thas just me tho
Old Oct 6, 2003
dragoon's Avatar
mine's a bit soft, but harder than my friend's protege5
Old Oct 6, 2003
nme3's Avatar
JDM wannabe
well this is the only manual car i ever driven but seems pretty soft to me
Old Oct 6, 2003
clownprince's Avatar
Ricerus Maximus
It's much softer than my 92 ranger and somewhat softer than dad's GSR. I can't wait to install one with a little more clamping force.
Old Oct 6, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Civic's have very soft clutches compared to other cars. I can figure 2 reasons for this,
1.) They were designed that way...
2.) They don't have to put as much pressure on the flywheel since we're not putting out that much HP, therefor it's easier to push down on. Also we have pnumatic clutch...
I've drived a Misto Eclipse, Much harder clutch, old toyota pickup, VERY hard clutch, 540I, not as hard as the toyota, be harder than the mitsu, and lastly a scoobyru impreza 2.5rs, which was somewhere between the eclipse and the civic.
Old Oct 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The only basis for comparison I have is my dad's BMW... and BMW clutches are on the stiff side of things. So of course the Civic feels whimpy. The stiffest clutch I think I ever played around with was the WRX one.
Old Oct 7, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
My clutch is a little stiff. That's only because I have a Centerforce Dual Friction clutch.
Old Oct 7, 2003
WD40's Avatar
WD40 is an unknown quantity at this point
My clutch is really soft. It's even noticibly softer than my '99 Civic. My theory as to why Honda makes the clutch so soft is for user-friendliness. Remember, Civic's aren't performance vehicles, they are econo-boxes.
Old Oct 7, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Yeah . .I've driven an RSX. . Much different on the clutching. I like the firm clutch alot better ..
Old Oct 7, 2003
flotsamm's Avatar
I believe ours is soft since the pressure plate springs arent as strong as others. Get a pressure plate with stronger springs and it'll make the pedal stiffer.
Old Oct 7, 2003
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
yes our cars have a very, very soft clutch, going back to what others said, honda did this purposly, cause our cars are economical, not performance. If you want to see a hard clutch go find an old mustang, you could get some with a 10 lb. clutch for the horsepower. I believe that these are some of the stiffest out there, nothing compared to a WRX.
Old Oct 7, 2003
4bangin's Avatar
ya the civic clutch is a ton softer than my prelude's clutch was but it is stiffer than my buddy's protege 5. it is about the same as my friends 97 civic and alot softer than my friends celica and my other friends 1.8t jetta.
Old Oct 7, 2003
Green Civic's Avatar
Civics have always had a soft clutch, unless you swaped it out for aftermarket clutch and whatnot. I like a soft clutch, even more when I am in rush hour traffic.
Old Oct 7, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
does your clutch have an air tank hooked you to it? does it sound like a turbo-blowoff everytime you press the clutch petal? i bet that compressor makes a lot of noise.
i have a hydrolic clutch, i can't afford air clutch........
Old Oct 7, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
lol.....our clutches feel like mashed potatoes, yet again, i do prefer it in the daily traffic routine though....
Old Oct 7, 2003
Renamazazo's Avatar
I meant Hydrolic, I always confuse the 2... Pnumatic and Hydrolic are very similar... one uses compressed air, the other a compressed liquid... and YES, I DO HAVE A TURBO NOS CLUTCH....
Old Oct 7, 2003
white2K2EX's Avatar
I sure wish my car was newer
My dad has a VW GLI and the clutch on that is a lot stiffer than the manual Civics I've been in. The stiffest clutch I've ever felt was in a Boxster my friend was thinking about buying. It was slightly modded, but I'm not sure if its clutch was like that stock or if it was aftermarket.
Old Oct 7, 2003
HondaLuver's Avatar
Its a celebration bitches!
what about cluchless shifting...
Old Oct 7, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
LOL... mines stiff... but thats probly cause its a 6-puck ACT...
Old Oct 8, 2003
Renamazazo's Avatar
I do this all the time in stop and go traffic, pretty easy to do if you play with it a little, just don't be afraid to ram it into gear when they line up, otherwise it will make a bad noise.
WaryDriver
May 27, 2015 05:54 AM
ayoitzjulesdx98
May 13, 2015 08:31 PM
NYNE
Mar 8, 2002 01:31 AM
artychris
Nov 3, 2001 12:20 AM
Unomyname
Sep 25, 2001 11:09 PM
