What is Double-Clutching?
Old Jul 15, 2003
ThatPhatCivic's Avatar
ThatPhatCivic is an unknown quantity at this point
Question What is Double-Clutching?
i've heard of double-clutching many times..but i've yet to find out. I know some people are going to try and cut on me for not knowing this..or even how to do it, but hey u people that know it and know how to do it..learned from someone..so now its my turn..how do u do double-clutching? what is it? what are the upside and downside to doing it?
Old Jul 15, 2003
white2K2EX's Avatar
I sure wish my car was newer
Clutch. Neutral. Rev. Clutch. Gear. Accelerate.
It's dumb. It's for people who can't shift fast enough to keep it in VTEC (like it really matters.) I'm gonna assume you heard it from the Fast & the Furious - it's just tech jargon they threw in to sound smart.
Old Jul 15, 2003
Zzyzx's Avatar
Autocross Junky
Let me guess.... Fast and Furious? (jk)
Double clutching, originally, was a tecneque nessisary for older manual transmissions to shift both up and down. the reason for this was older transmissions did not have syncros yet, so in order to not grind the gears when you shifted, It was nessisary to revmatch every gear.
(My partents owned an old chevy pick up where you had to double clutch)
The process is:
1. clutch in, shift in to nutrual.
2. tap the gas (Revmatch if your down shifting)
3. clutch in, shift in to next gear.
Modern cars have syncros, so Double cluting is no longer nessisary.
I know that some people mistake Heel-toe shifting with Double clutching some times.
Heel-toe shifting is a process that allows you to use the clutch, brake and gas all at the same time, so you can down shift durring a corner (rather then before the corner)
Old Jul 15, 2003
Yes. I did hear it on Fast and the Furious, but my dad told me about it first and when i heard it in Fast and the Furious i thought i should look into it.
Old Jul 15, 2003
Oh..and thanks for the help :-x
Old Jul 17, 2003
imPHOrt racer's Avatar
imPHOrt racer is an unknown quantity at this point
Double clutching is a technique just used to match RPM's with speed, for instance if you get a bad launch or perhaps misshift, Double clutching is nothing more than being in gear, stomping on gas and while your accelerating push the clutch down quickly and releasing it quickly, ull jump RPMS real quick but dont think it makes you faster, b.c. it doesnt just helps you regain some trq or whatever IMO dont do it if not necessary, waste of clutch and time sometimes
Old Jul 17, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Ya no big deal.. The only time I've though it helpful is if you're downshifting to the point where you're RPMs are going to jump to about 4 or 5. For instance if you're going like 30 -35mph and you want to kick it down into 2nd without going through the windshield. Then you can rev her up to about 4k or so before you let out the clutch and it'll be a little smoother.
Old Jul 17, 2003
cdmx's Avatar
here you go....I think we thank grey for this one:http://www.happytogether.com/318ti/n...ing/index.html
Old Jul 17, 2003
CivicHX01's Avatar
ahhhh... its the good ol' ricer definition of dbl clutching....
Old Jul 17, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
AHAHAHHAHAHHA
Old Jul 17, 2003
Drnknmnky13's Avatar
The process is:
Above statement is correct. Anyone that tells you double clutching gets you more power or "helps" you in any way is an idiot. Unless your syncro is bad it is completely useless to you. Now ask about speed shifting..I want to see what some of these goons say it is. For the record it's not just regular shifting but faster.
Old Jul 17, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
haha I used to have to do this in my old car when the syncro's were shot. Probably the biggest pain in the *** IMO.
Old Jul 17, 2003
Hondasport2k3's Avatar
i gOt da MaJik stiK
Hondasport2k3 is an unknown quantity at this point
thank goodness for syncro cuz id be to retarded to double clutch. btw, this is like the 10th thread on double clutching
Old Jul 17, 2003
pbfoot's Avatar
hahaha...amen brotha!!
so what is speed shifting?
Old Jul 17, 2003
Kape's Avatar
Kape is an unknown quantity at this point
yeah, what is speed shifting? and I have a question about Fast and Furious... maybe it's just for the movie, but in the first one, at the very begining (as well as during the races) they show the guy flooring it in the eclipse, he takes the foot completely off the gas, presses the clutch, shifts, then completely releases the clutch, before flooring the gas again. Now... 1st, how does that not jurk the car cuz they never show the driver moving back and forth, and 2nd, how does that give you the best acceleration, wouldn't pressing the gas while releasing the clutch give you a quicker shift in the long run?
Ahh, maybe I'm picking at the movie too much, 80% of the races go through 16 gears, every other second they change gears.. like, dude, there's no more!, anyway
Old Jul 17, 2003
crazydragon's Avatar
crazydragon is an unknown quantity at this point
speed shifting is being able to change gears without useing the clutch. hard to do with a normal tranny but most full racing trannys can be done easaly.
Old Jul 17, 2003
Zzyzx's Avatar
Autocross Junky
even in racing, it has been proven that speed shifting is no faster/better then normal shifting (Im talking about road racing I dont konw about drag). aslo, its been determined that the increaced chance of damaging the transmission is not worth what little time you may save by not using the clutch.
Old Jul 17, 2003
pbfoot's Avatar
ooooh...i always thought that was called "power shifting." i knew what that is then. id never do that tho, it totally ****s your tranny. i mean i can hit the sweet spot pretty often, but its still not every time...just doesnt seem worth it to me to speed/power shitf
Edit: to Kape: fast and the furious = movie! movies dont show realistic anything, unless its a documentary. its all glitz and glamour, especially in that movie. might be fun to watch, but dont think its an accurate depiction of actual driving techniques.
Old Jul 17, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
As far as double clutching, I had to do that when I owned a mustang. The second gear synchro was so bad that double-clutching was the only way to get it into gear. Neadless to say, I replaced that tranny. And as far as shifting with no clutch, I had to do that on a dirt bike when I had broken my "clutch hand" in two places.
Old Jul 17, 2003
perry's Avatar
perry is an unknown quantity at this point
thats not really double clutching... but i hear that technique refered to commonly as double clutching. i guess you could call it the nu-double clutching, since synchromeshing has taken care of the old problem for us. However a lot a deisels still require dbl clutching for downshift. I know i have to do it in my dads truck... but yeah, two things both called the same thing... real dbl clutching is placing the vehicle in neutral and reving, then putting it into gear.
p.s. the aforementioned nameless technique can be duplicated with some automatic transmissions. by placing the vehicle in neutral then back into drive. However some vehicles have a fuel cut-off that will engage to prevent tranny damage. ;P
Old Jul 17, 2003
perry's Avatar
kane, lol i noticed that too....
i was in the theater going ...
"bwaaaaaaahhhh, 2nd!...bwaaaaaaa, 3rd... naaaaaaaaaaa, 4th, naaaaaa5th, 6th, brrrrrr, 7th, bwaaaaaa 8th, w00t, im in 18th gear, eat that you ricers!!!!!"
Old Jul 17, 2003
Shambler's Avatar
I'm an idiot.
Shambler is an unknown quantity at this point
I saw FnF2 twice, cause there was so much stupid crap i missed the first time around in the theater. I hate and love those movies at the same time
Old Jul 17, 2003
white2K2EX's Avatar
Haha... I downloaded 2F2F. I watched the first part with no problem, then the second part... it was the 2nd half of X-men 2 with Japanese subtitles. So I guess I'll have to wait until the DVD comes out to see who won that tag-team race. I waited too long to see it in the theatre coz I was gone for the month of june
Old Jul 17, 2003
Robthe54's Avatar
Robthe54 is an unknown quantity at this point
speed shifting-
with the pedal to the floor in a gear (holding it in gear) apply pressure to shift lever. push the clutch in and "hurl" it into your next gear, it's also called "slingshot shifting, catput shifting... etc etc" the only performance gain here is in terms of braking your syncros.
slip shifting-
slow, speed matched, clutchless shift
power shifting-
in a big v-8 you don't always shift at redline, you shift where your (gear) mutiplied torque is falling below what the next gear would give you... to pwer shift, you shift the car without removing your foot from the gas... it makes a sig. difference... if you've got a 400CI torque monster... not a civic tho
i dbl clutch personally... for me it's smoother, it reduces the wear on my trans, which takes enough abuse already (3rd one :/ ), and it's a good skill to have handy if you like to corner at high speeds...
Old Jul 17, 2003
Naito's Avatar
Naito is an unknown quantity at this point
Fast & The Furious = the last place to look for technical accuracy
2 Fast 2 Furious = 1 multi-million dollar 2 hour long honkin big rice boy ad
:thumbdown: :thumbdown:
Old Jul 17, 2003
cdmx's Avatar
Im able to pull it out of gear no problem but not able to get it in gear as easily(without the clutch)...Ive done it mabye a few times....Speed/Power shifting that is
Old Jul 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
DON'T DOUBLE CLUTCH!!! Our transmitions cant take it.
I used to double clutch on the race track, and I burned
up my synchros between 2nd and third gear. When I shifted
fast you would hear the gears grunt.
Luckily I had the honda dealership replace it all under
warrenty and they also threw in a new clutch since it
was all apart.
Your taking a risk double clutching. It only took maybe .1 to .05
seconds off my 1/4 mile time..don't do it.
Big rigs have to double clutch in order to advance to the next gear!
Old Jul 17, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
kjgracing: I think you meant that you were "speed shifting" at the track because there should be absolutely no reason to double clutch at the track, it will just waste your time. You shouldn't have to downshift when drag racing only upshift.
Old Jul 17, 2003
pheaton's Avatar
Anyways there is this one goof ball that I know. . who by the way doesn't have an engine anymore. . He mashed the gas to the floor and never let up. When he shifted, he still clutched, but never let off the gas. Inevetably he shot a rod through the side of his motor. Is there a term (besides) moron for that?
Old Jul 17, 2003
Anyone want to race my Integra? I wont even speed shift, double clutch or whatever you guys claims help ya, if ya got a fast car ya got a fast car....60% driver 40% car I believe, most people think 90% driver 10 % car if ya believe that take me on with a 7th gen, or hey maybe even a Type R if ya want hehe
