General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Starter Kill Relay
Old Nov 2, 2018
Colin42's Avatar
Starter Kill Relay
Want to install a starter kill relay on the girlfriend's '99 sedan (auto, d16y7).
Something failed with the remote start causing the starter to engage with the engine.
I know I should remove the remote start but we live in Canada and I don't want to become single.
What would be the best wires to tap into to have the remote start's starter wire be disconnected when the engine is running.
I have a 5 pole relay, start wire would be on the NC contact and then become NO when the coil is energized.
Thank you
Old Nov 2, 2018
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Starter Kill Relay
Has it happened more than once? Are you sure it isn't just a bad relay sticking. Most remote start kits come with cheap no name relays.
Old Nov 2, 2018
Colin42's Avatar
It did it to me when I replaced the starter and started the car, a few seconds later the starter engaged,
luckily I was able to pull the negative cable before the starter fried. Then I disconnected the module so that the car would still be driveable.
I'm going to be looking at the module and all the related wiring tonight, I'm thinking either the module failed, or the twist and tape job the installer did is causing problems
Old Nov 2, 2018
Colin42's Avatar
might be hard to see in the picture, but it looks like the board failed. Something arced on it. Looks like the drivers kick panel is not the best place for it
medo
May 6, 2016 01:40 PM
jimwe
Feb 6, 2013 10:28 PM
1992civicdx
Jan 4, 2011 09:37 AM
Imtheconvict
Jan 16, 2006 01:49 PM
01rpst
Mar 8, 2005 07:51 PM
