General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Piece of rubber inside radiator.
Old Apr 24, 2018
Calgetty's Avatar
Calgetty is an unknown quantity at this point
1997 Honda Civic EX (D16Y8 engine)
I noticed that the coolant level was dropping inside the radiator. I would just add a little more coolant. There were no visible leaks. Yesterday, I removed the radiator cap and saw a piece of black rubber floating inside, (see pics).
I removed the piece of rubber, but have no idea where it came from. The rubber seals in the radiator cap are intact and not damaged.
I checked the radiator hoses (which will be replaced) and they weren't damaged.
ID:	112153   Click image for larger version
ID:	112154   Click image for larger version
ID:	112155   Click image for larger version
Old Apr 25, 2018
Wankenstein's Avatar
Re: Piece of rubber inside radiator.
Replace the radiator cap. Purchase a Honda genuine (OEM) cap from local dealer or certified Honda parts dealer online: such as HondaPartsNow.
After-market caps do not fit as well.
Old Apr 25, 2018
Chunk of thermostat gasket?
Old Apr 25, 2018
Calgetty's Avatar
Thanks! I'll be betting an original Honda cap and radiator hoses. I didn't find any leaks in the radiator.
Old Apr 25, 2018
Take Ezone's suggestion over mine. Remove and inspect the thermostat gasket first.
Even before that either get the car on a lift while it's running and inspect for leaks or place a large piece of cardboard (size of engine or larger) and run engine for 15 minutes or more to try and locate a possible leak.
qijian
15
Jul 18, 2008 05:55 PM
revern
Sep 29, 2006 04:25 PM
FurBall
Jul 22, 2006 10:23 PM
Synapse
Aug 19, 2004 01:09 PM
LnkinParkPunk
Nov 26, 2003 03:13 PM
