General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
91 civic engine 1.5 liter in an 88 crx
Old Jul 23, 2021
Jammes48's Avatar
Jammes48 is an unknown quantity at this point
I had to put a new distributor on a while back, I installed it, ran it, Everything seemed fine but when it got hot it kept stalling, I checked the sensor in the distributor, it was bad, got another tested it, installed it, still stalls when hot. I've been trying to do the timing, I read in a Chilton book the car needs to be ran long enough for the fans to come on before I can jump the timing connector but I can't check the timing cuz it stalls when it's hot. The idle barely goes up or down when I adjust the distributor when it's still cold. I don't know what else can be the problem. Should the pistons been in a certain position when I installed new distributor? Is it a fuel filter or fuel problem? Is it a sensor gone bad somewhere? Please help!
Old Jul 23, 2021
FRSam's Avatar
Click Here
Re: 91 civic engine 1.5 liter in an 88 crx
Was it an OEM sensor?
Old Jul 23, 2021
Jammes48's Avatar
I don't think so, I'm not sure really, I do know that it works, before I installed it I got it tested, installed it and it still stalled when hot, took it back to get tested again and it was still good. The distributor is from auto zone with a lifetime warranty cuz I kept blowing thru distributors. What do you think could be happening?
Old Jul 23, 2021
Colin42's Avatar
Return that garbage aftermarket distributor and go get an OEM one from a junkyard
civic.ek1
Aug 31, 2020 01:37 AM
C24Creed
Sep 23, 2017 10:52 AM
Onyx98
Jan 14, 2016 12:31 AM
waldonian
Jun 9, 2013 11:52 AM
B18_civic
Jul 16, 2011 09:08 PM
