General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
1st gen parts needed
Old Feb 24, 2020
Matthew Durber's Avatar
Matthew Durber is an unknown quantity at this point
Parts help needed
Hi all, I have a 1976 1.5 civic and am currently trying to source a set of cylinder head bolts and a rear silencer, could anyone point me in the right direction ?
any help would be greatly appreciated.
regards
Mathew
Old Feb 24, 2020
Hi, I am currently trying to source a set of cylinder head bolts and a rear silencer for my 1976 1.5 civic, can anyone point me in the right direction please.
Any help would be greatly appreciated.
Regards
Matthew
Old Feb 24, 2020
FRSam's Avatar
Click Here
Re: 1st gen parts needed
I realize this is probably the first place you looked, but have you tried RockAuto? I've had the best luck finding small pieces on there.
eBay would be my next guess.
Old Feb 24, 2020
hi, thanks very much for that, I’ll give them a try .
regards
Matthew
Old Feb 24, 2020
Re: Parts help needed
try to contact them to see if legit? (I don't know if they are, simply found in googling
again, be careful, internet can have all sorts of things...
https://parts.sonshonda.com/cars/Hon...car-parts.html
https://www.hondapartsnow.com/1976-h...4mt-parts.html
Old Feb 24, 2020
ah, carid used to be a sponsor of the site, so we know they are legit.
ah, merged your two threads into one, later on it gets confusing with two threads with different information.
https://www.carid.com/1976-honda-civic-accessories/
Old Feb 24, 2020
Just e-mailed them so fingers crossed, thanks for the advice 👍
Old Mar 1, 2020
Still no luck with these parts, these are tough cars to find bits for 😅
Old Mar 1, 2020
good luck... really hard after so many years past by...
Old Mar 1, 2020
That’s true, I think my only hope for head bolts is to go to a supplier with mine and compare them with others, there must be some for other cars that are the same .
Old Mar 1, 2020
Man, my Google-fu is failing me right now. I didn't imagine it'd be this hard to find those bolts. Buuuutttt... I did find this site that specializes in first gen civic parts in case you need anything else. Who knows, maybe if you e-mail them, they may be able to hunt down either a) a set of them or b) proper dimensions so you can use something that'll work
Old Mar 2, 2020
Thanks very much for looking, much appreciated, my preview car was from 1951, I could get bits easier for that than for my civic. I’ll give that place a call and hope for a miracle 👍
Old Mar 2, 2020
Just spoke to a supplier who said he had a feeling that Honda may not have used stretch bolts back then and just because the head is alloy it’s not always the case that stretch bolts were used.
does any one know from experience if they are stretch or not ?
Old Mar 2, 2020
Colin42's Avatar
I know the newer Hondas (90s +) don't use torque to yeild bolts, they just just normal ones, got a manual that gives you the procedure for the head bolts? That will give you clues if the bolts are torque to yeild or not
Old Mar 2, 2020
I think I do have a basic manual, I’ll take a look. I have just spoken to a parts guy at the main dealers, he also seems to thinks they were not stretch bolts and advised me to contact Honda UK which I have just done, they’ll get back to me once they have an answer, I can only hope they are not stretch.
its annoying because the head only had to be removed in order to have a broken bolt from the thermostat housing removed 😕
Old Mar 2, 2020
Colin42's Avatar
If you still have the old head bolts and they're in good shape you can reuse them. Seriously
Old Mar 2, 2020
That’s what I’m thinking, I may not have a choice to be honest, 1 needs reshaping on the top due to rounding off slightly, I know where I can get that sorted. I’ll see what Honda Uk come back with 👍
Old Mar 2, 2020
the 7th generation don't use stretch bolts (that's actually one of the suspected causes for the headgasket failing so much on those...)
Old Mar 3, 2020
That’s a bad issue to have so far down the line. My local cylinder head engineer may have come up trumps for me yesterday, he’s been trying for a week to find an alternative used on a different car, got me a set for a Fiat which have the same thread and dimensions. Very helpful, fingers crossed it goes back together ok 👌
Old Mar 3, 2020
Worst comes to worst, have a machine shop fab up some fasteners. Lol. Would just need specs
Old Mar 3, 2020
It’s an option but I hope these Fiat bolts will do the job, thanks anyhow 👍
robfarr56
Aug 13, 2017 10:00 PM
7m6m4
South Cali
19
Nov 12, 2004 05:22 PM
eviLsliDinciVic
Oct 19, 2003 11:57 AM
iamboo
South Cali
Aug 12, 2003 11:25 AM
