Bolt-on Engine Performance This section is for easy bolt-on engine modifications Post questions/information about intakes, exhausts, headers, lightweight pulleys or flywheels? It belongs here.
what parts to use to add a little more engine power? R18
Old Apr 15, 2018
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
hello guys i own a civic 2008 sedan with a r18 engine 5sp how would i go about gaining some more power from my r18 1,8 engine im not useing it to do any drag racing or nothing of sort just wanting to gain a little more power on the engine side of things
Old Apr 15, 2018
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Re: what parts to use to add a little more engine power? R18
You can change a few parts or get a HONDADATA Flashpro for Re-Flashing Your DX Civics ECU yes expensive but so are performance parts and Labour inst. it will work well on Your DX. better gains are on a SI & 1.5 Turbo, or more so Yet ultimatley on a 2018 Type R.! If You want to leave it stock as is with-out replacing Parts...? then get the ECU re-Flashed.! using HondaData Flashpro.
http://hardmotion.com/shop/fuel-tuni...data-flashpro/
Old May 5, 2018
hey guys i caled my local london honda this week enquiring about the hondadata reflash they told me if i wanted to come in and get it reflashed it would cost me just over 1.100 dollars i enquired about h.p gains he said we have not done a lot of them on civics but the few they have done gained some great results on power gains 1 owner called back and said his cars engine was alot more robust on power.! im seriosly thinking of getting it done and adding a cold air intake for added power.
Old Mar 15, 2019
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
Consider lower restriction exhaust mods to complement the cold air intake. The combination gives the car a considerable responsiveness boost.
Old Mar 20, 2019
mac25's Avatar
Dr Krieger of Modification
-intake
-header
-exhaust
-camshaft if you can find one (not sure if they're commonly produced from mod companies, for that engine)
-weight reduction
Old Mar 24, 2019
brags's Avatar
Originally Posted by mac25
-intake
-header
-exhaust
-weight reduction
Yes all those are great to have on i would use a HondaData Flashpro to further fine tune bolt on parts and Parameteres like the air/fuel ratio, spark advance timing, Governor Speed its got the ability to adjust the Factory ecu settings that are more suited for better fuel economy and emmisions. HondaData Flashpro is worth the $ for much better H.P. performance,
https://www.procivic.com/pages-performance/index.html
Old Mar 31, 2019
hifive's Avatar
hifive is an unknown quantity at this point
flashpro great gadget aint cheap though.
Old Mar 31, 2019
brags's Avatar
That's True the cheaper version to hondadata would be using something like a KTuner re-flash that's identical & little cheaper. still i like the hondadata more so its got diagnostics built in for diagnosing, something that KTuner dont.
https://www.hondata.com/help/flashpr...ics_window.htm
kmarcet
Sep 26, 2015 10:25 PM
arodgers92
Feb 28, 2008 07:17 AM
04SUPER_civ
Feb 16, 2005 04:36 PM
flowerpowerlove
19
Jan 30, 2005 03:15 PM
HeRbaLuS
Mar 1, 2002 08:38 AM
