General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Wind noise??? [solved]
Old Jul 18, 2021
Ksb's Avatar
Ksb
Ksb is an unknown quantity at this point
I am considering buying a 2016 EX sedan. On the test drive I heard a noise that seems to be coming from rear of the vehicle. It starts to be noticeable starting around 55 mph. At first I thought it was a throaty exhaust sound. As the speed increases the sound increases in frequency. At first I thought it might be road noise or maybe tire noise. When I looked underneath the car I see that there appears to be sound deadening material. There are two panels. The one on the passenger side has a slight v shape bend to it that may not be normal, and the one on the drivers side appears to have one mounting clip loose and maybe others missing. I am thinking these are the source of the sound, and that making sure they are secured properly will eliminate the noise. Thoughts on my theory are appreciated.
Old Aug 3, 2021
Ksb's Avatar
Ksb
re: Wind noise??? [solved]
In case anyone is curious. The issue is uneven wear on the rear tires. Previous owner never rotated tires. 31k miles.
Pete6032
Exterior
Aug 22, 2018 12:05 PM
dchawkin
Jan 18, 2011 08:11 PM
lambada
Mar 20, 2008 01:15 AM
gotrice
Jul 6, 2004 12:14 AM
HONCIV2K1
Feb 28, 2002 12:49 AM
