General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Thinking about 2017 Honda Civic SI
Old Jun 13, 2021
98dx_'s Avatar
98dx_ is an unknown quantity at this point
Hi all,
so a couple of years back I have a 98 civic DX as you can tell by my username and it was a very fun car to drive and I loved being able to drive it, using any excuse to drive my 5-speed manual as it was my first manual car. Anyhow flash forward of me owning the car for not even a year and unfortunately, I have problems with the car every other week, and I was forced to sell the car because it became too unreliable. I don't know if it was because of how I was driving the car or if I just have bad luck with cars, but nonetheless, It felt like every other week I would repair something and something else would come up to where I would have to fix it. As of right now, I own a 2017 civic auto and honestly, I want to go back to a manual so I'm thinking about trading in my 2017 base model civic for a 2017 SI. My question is, how reliable is the SI without mods and with mods? I want to eventually turbo this car and do performance mods on the SI so at what point does it become less of a daily driver and more of a hassle to maintain the modifications? I think I've read in other forums that civic engine blocks can handle around 450-500 hp and around that in Torque before they crack. Ultimately I would like to be able to daily drive it and take it to the track and have it be reliable all at the same time, but a little more extra oomf? would be nice (the turbo will come a year or two later down the line once ive gotten used to the base N/A SI)
thanks for your time?
Old Jun 13, 2021
FRSam's Avatar
Click Here
Re: Thinking about 2017 Honda Civic SI
The K24Z (engine in the Si) actually doesn't have a ton of engine aftermarket (very similar engine to that of my TSX so I've done a ton of research). From factory, they are very reliable cars. I'm about to hit 160k miles on mine with mixed driving.
Full bolt-ons while keeping it NA is more than enough to have fun and stay reliable. 500hp in a FWD platform would be almost undriveable on a track, not to mention daily driving
If you require forced induction, they respond very well to supercharging, and it maintains good reliability.
Old Jun 13, 2021
10thgen Si has the same base engine as the non-Si turbo models (hatchback base model is the 1.5T, coupe/sedan base model is the K20 non-turbo). As far as I know, they haven't used the K24 in the current generation of any Honda models.
Biggest differences between the Si and non-Si turbo models is the MAF sensor (digital vs. analog), rods (beefier than the non-si counterparts), compression ratio (10.3:1 vs 10.6:1), and the exhaust wheel on the turbo (blade count to produce more boost for less).
Old Jun 13, 2021
FRSam's Avatar
Click Here
Even better. You don’t need to turbo it.
I guess my mind went K24 when he said he wants to turbo it.
Old Jun 14, 2021
98dx_'s Avatar
could you explain why I don't need to turbo it, are you saying that there are performance mods for the intercooler, intake, etc etc?
Old Jun 14, 2021
it already has a turbo. 10thgen Si is equipped with the same L15 series 1.5T engine (same as the other 1.5T equipped non-Si turbo Civic, CRV, and Accord), albeit with a few "modifications" from the factory (the aforementioned rods, turbo exhaust wheel, MAF sensor/housing, compression ratio) that allow it to accommodate/produce more boost (20.3psi from factory vs. the 16.5psi in the non-Si Civic turbo)
edit: you can definitely upgrade the existing intercooler, piping, intake, turbo inlet pipe, the turbo itself, etc., the latter of which would require a custom tune. Stay away from vent to atmosphere blow off valves since the 1.5T utilizes a recirculating bypass valve (BPV). If you were to use a VTA BOV, it'd take metered air out of the intake stream, and you'd end up running rich.
CivicDoc-18
General 10th Gen
Oct 3, 2018 08:34 AM
Panda_kRz
Oct 14, 2014 07:55 AM
cateyes221981
Buy, Sell, & Trade - Archive
Apr 30, 2008 06:39 AM
