General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Front End Lift Point
Old Jun 7, 2020
Saratoga's Avatar
Saratoga is an unknown quantity at this point
Is there a front end lift point for a 2020 Civic? I would like to lift the front end up with a hydraulic jack so that I can place jack stands under the car. My 2009 Civic had one under the radiator.
Old Jun 7, 2020
Re: Front End Lift Point
There's one kinda deep centerline, behind the big *** aluminum panel you have to remove for oil changes. I'm trying to find a good undercarriage picture so I can highlight the area
edit: picture is of an FK8, but effectively same undercarriage. The chassis point you can use circled in yellow, then jack stands can go at the factory locations/where they have the lift pads
Old Jun 9, 2020
Saratoga's Avatar
xRiCeBoYx thanks for the picture. Found this which shows the rear lift point also.
Old Jun 10, 2020
GolNat's Avatar
Prelude Owner
If you can't reach under it far enough with your jack you can try lifting one rear side. This will usually get the front wheel high enough to get a stand under it.
Old Jun 10, 2020
What I've done is use my rhino ramps to get the front end off the ground, jack it up just enough to clear the ramps, then put jack stands. I use strictly rhino ramps if I'm not doing anything wheel/suspension/brake related
Kylepk
8th & 9th Gen Do It Yourself Articles
Feb 18, 2017 03:38 PM
Dntn
Jul 18, 2010 02:01 AM
dpt
Mar 29, 2007 09:23 PM
sinfulinside
Jun 16, 2006 02:10 PM
Elite
Jun 27, 2003 01:21 AM
