tpms light!
tpms light!
Hi there!
I recently bought a new 2018 hatchback ex-l navi on Saturday. On Monday, the tmps light came on. I checked the tires, they were all inflated to 50. I deflated them to 32. Next day, back on. All tires still at 32. Meanwhile, I've called the dealership 2x to complain, especially since I drove 100 miles away to get this particular car. I googled it, and it seems this is a common problem with 9th and 10th generations? I traded in a 9th and didn't have this problem. I made the appointment with the local honda dealer to get the update I found while googling. that afternoon I get in the car and the whole display crashed. I can only use the power and volume buttons. my salesman is off, so i'm talking to the sales manager and he asks why im so upset, it's covered under warranty. I'm mad because I have to take it to the dealer I didn't buy it from and it's not even a week old! Oh, and I have to drive it back to the original delearship (an hour away) to get the splash guards on. Has anyone else had this problem?
Thanks,
Corie
Thanks,
Corie
Re: tpms light!
Every time you do ANYTHING with tires you MUST manually reset/recalibrate the TPMS system. Air them up or down, rotate, any change at all. On a car with a DA radio the tire cal is done in the menus. See your owners manual.
Radio crash is another matter. Let warranty handle it.
Off topic, why didn't you purchase the car from your closest dealership?
Re: tpms light!
I did recalibrate. I guess I didn't explain myself. After I found the tires were inflated to 50 psi (which the light IS NOT supposed to come on for btw), I deflated them, recalibrated, it turned off and it came on again the next day.
And yes, after reading my manual, I discovered that if there is something wrong with the system, the light will flash for approximately 1 min when you start the car. Mine did not do that. I did read right before my radio crashed that for 9th and 10th generation civic owners, when there is a problem with the tpms system, it will crash the rest of it. I only could find that in 1 article though, so I was looking for some confirmation if that was the case.
This is not my 1st civic. I have owned a 7th, 9th, and now 10th generation. My 9th had a slow tire leak so I know all about resetting the tpms light as the system has not changed from my 2015 to my 2018.
Regarding why I didn't buy from my closest dealership; I have owned 5 Hondas in my lifetime, so I have experience with our local ones. When my lease was up on my 15, my local dealership kept passing me around. The had 2 civics total in the lot. No hatchbacks. The one an hour away had 50, including 20 hatchbacks. Since I like to see the differences, I drove there.
thanks for your help.
Re: tpms light!
How did you recalibrate?
When I discovered mine were at 55psi, I took em down to 32 then took a 30 minute drive on the freeway staying at about 65mph. Iirc, manual says to drive between 35-65 for a half hour. I haven't had my light pop back on yet
Re: tpms light!
Was the car parked on level ground when you did the tire calibration?
One thing we often do in the shop is repeat the cal procedure 3 times in a row. This supposedly erases the previously learned tire profiles and is mostly done when we have a warning light on but the pressures are actually correct and no changes are made.
Hit calibrate once, wait 5 seconds, hit it again, wait 5 seconds, hit it a 3rd time.
About 5 seconds later the "(!)" light on the dash should turn on for a second and go out.
Drive it at your leisure.
desertfox1955
Sep 19, 2017 10:49 PM
crimson_pearl
Dec 10, 2014 06:36 PM
