Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
2021 sport wheel upgrade
Old Jul 13, 2021
22h2's Avatar
22h2 is an unknown quantity at this point
Hello everyone, new to the forum and was needing some information on wheel fitment, I have a sport with 18" wheels and I would like to go to 16 or 17 for a better ride, are there any known issues or concerns? I haven't ask but does anyone know if this would affect the warranty?
thanks
Old Jul 13, 2021
FRSam's Avatar
Click Here
Re: 2021 sport wheel upgrade
You may not be able to go as low as a 16, but you should be able to go with a 17. Aside from it looking a bit strange, you should be fine. It’ll only void warranty if the wheels contribute to some failure (ie premature trans wear based on improper wheel size). Just be mindful of that when picking a set out and make sure it’s within spec of the factory setup.
If you’re looking for a comfortable ride, I probably would have gone with the touring trim.
Old Jul 13, 2021
Shouldn't have any issues. Some trims came with stock 16s (16x7 et45 with 215/55R16 tires) and others with 17s (17x7 et45 with 215/50R17). Sport trims don't have fancier or bigger brakes or different suspension than the LX/EX trims. Neither do the hatchback vs coupe/sedans, so you're good there, if that's the case.
If changing wheels voided warranties, the automotive world would have a fit. Dealership would have to prove that the part caused the issue to be able to void that part of the warranty
Old Jul 13, 2021
22h2's Avatar
Thanks for the replies, I believe I will go with the 17 that should help the ride some.
Old Jul 13, 2021
FRSam's Avatar
Click Here
To be honest, you probably won’t notice.
Retta75
Apr 21, 2019 12:06 AM
civicgal721
Jun 22, 2005 09:55 AM
zen_master
49
Mar 28, 2004 01:52 PM
ZRPM
Jun 25, 2002 02:26 AM
ZRPM
Jun 23, 2002 11:38 PM
