Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
2020 Honda Civic LX Sedan 18 inch wheel fit
Old Dec 16, 2020
ElderJoe1's Avatar
ElderJoe1 is an unknown quantity at this point
Below I have provided the specs of a new set of rims that I would like to use on my 2020 Civic LX Sedan.
SPEC-1® - SP-15 Gloss Black with Machined Face and Red Accents (18" x 8", +38 Offset, 5x114.3 Bolt Pattern, 73.1mm Hub)
Would any one be able to confirm.
Thanks
Joe S.
Old Dec 16, 2020
Re: 2020 Honda Civic LX Sedan 18 inch wheel fit
OEM spec for 18's that came on the Si's and Sport/Sport Touring is 18x8 ET50 5x114.3 with a 64.1mm hub.
Will it fit, yes. I've been looking at 18x8.5 et35's myself, which will push the rim further out than the ones you're looking at
wheel-size.com is a wheel calculator I use quite frequently. Give you insight as to the difference in clearance and speedometer readings with new wheel/tire sizes. This link here should be all lined up to compare your OEM 16's to the 18's you're looking at.
Old Dec 16, 2020
ElderJoe1's Avatar
Thanks for the reply xRiCeBoYx,
So will the lug pattern (I think its called) work with the 2020 Civic LX Sedan.
Old Dec 17, 2020
Yep. The 5x114.3 lug pattern is pretty standard for​ most​​​ 5-lug Hondas. Exceptions to the rule are the 2017+ civic type r and the nsx that have 5x120 lug patterns. They also have m14x1.5 lug studs, compared to the otherwise honda standard m12x1.5 lug studs on pretty much every other honda
Oh, forgot to mention about the center bore. It'd be recommended to get hub centric rings that adapt the new rims 73.1 center bore to the civic's 64.1 center bore. They're fairly inexpensive
Last edited by xRiCeBoYx; Apr 7, 2021 at 10:02 AM. Reason: Added more info for future readers
Old Dec 17, 2020
ElderJoe1's Avatar
Thanks for the peace of mind, just need to get a cheap set of 18inch wheels for the winter tires. I'm already missing the studs. It handled well in is first winter storm though, need to get over and have it under coated. I was able to get them to include a free oil undercoat.
Old Apr 7, 2021
H.Ahmed1's Avatar
H.Ahmed1 is an unknown quantity at this point
Hey guys, I just bought a 2021 Honda Civic sport sedan, I was just wondering what size wheels I should be looking at and all the details I should know about my wheels so I can find the perfect wheels for my car. It's bone stock atm, but hopefully throughout the year I will be doing much more to it.
Old Apr 7, 2021
rim size/width and off-set and tire size that fits and will not throw off speedo too much
Most tire/wheel websites will only show you the wheel/tire that fits (obviously they have more experience with the cars than us who have only one car)
tires rack is the one i use.
Have you already read what was already discussed here?
aus10
Apr 13, 2015 09:26 PM
civicrider01
Nov 7, 2005 11:39 PM
AntiLoop
Dec 22, 2004 07:54 PM
JLODVO
Aug 20, 2003 07:36 PM
IllusiveImports
Arizona
Jan 22, 2003 10:12 AM
