Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Tire help
Old Sep 23, 2017
Ashallen3322's Avatar
Ashallen3322 is an unknown quantity at this point
Tire help
I just bought a 2017 honda civic ex with Honda sensing, car has 400 miles on it now. I had to replace the back tire because of a screw in the sidewall. I put same size and all the just the the tread pattern is a little bit different because they don't carry the same tire in stock. Once I replaced it every single light possible popped up on the dash. Power steering problem, brake system failure, brake assist failure, Lane departure failure Etc no kidding every warning light possible. I tried to recalibrate the tires that didn't work. I took it to the dealership and they are telling me every single tire on the car has to be exactly the same brand and style. And that's why I'm getting all the warning lights. Does anyone know if this car is correct or they're just trying to screw me?
Old Sep 23, 2017
Re: Tire help
Can't do that. Order the exact matching tire.
Did they tell you any of the fault code numbers or give you a printout with all the codes from all the modules?
Old Sep 23, 2017
Re: Tire help
I just went and got a tire everything is good now
Old Sep 25, 2017
Re: Tire help
that's a problem on the modern cars - too many sensors...
I remember when i threw my miata's tires (205/50R16) on the rear of the civic, with the 205/55R16 in the fronts. ABS went like a Christmas tree in a few yards!
