10th Generation Civic 2016-2021 Discussion for the 2016 to 2021 Honda Civics.
Chassis codes: FC1, FC2, FC3, FC4, FK4, FK7, FK8
2016 Civic Ex-T
Old Dec 22, 2016
LimitK0's Avatar
LimitK0 is an unknown quantity at this point
2016 Civic Ex-T
So before I get flamed, I'm completely new to all of this.
Anyway, driving from Florida to California, I ended up racing a few cars. I topped out at 126-127 before it cut off. I run 93 octane and everything is still stock.
I was wondering what I could buy for minor upgrades to start? Also I was looking at the hondata flash pro and was curious if anyone has had experience with it and if it works? I just want a better tune to my car but I don't want to damage anything before I get the parts to upgrade first.
Any good advice ?
Used Low w/ traction on
Vs Acura TSX -- win
V6 Honda Accord -- lose
BMW m3 -- lose
First item I looked at was the injen cold air intake made for this vehicle apparently adds 20-25 more HP
Races were on i10
Old Dec 22, 2016
Re: 2016 Civic Ex-T
You may want to inquire on one of the 10th gen Civic forums
http://www.civicx.com/forums/
http://www.10thcivicforum.com/
Also understand that if anything goes wrong after you modify your car, problems may not be covered by warranty.
Old Dec 26, 2016
mac25's Avatar
Dr Krieger of Modification
Re: 2016 Civic Ex-T
It looks like you're sitting stock at
174hp and 2700 pounds, so your power to weight ratio is 0.064
an e36 m3 for example has a power to weight ratio of 0.088 (282hp and 3200 pounds)
So your target P to W is at lease a 0.09 if you want to hunt e36's.
You would need 243hp and stock weight to hit 0.09.
That's only a 69hp increase, which seems quite possible.
So in order to get faster you can either loose weight
gain power
or do both.
You have a major advantage to most civic owners in that your car came boosted, so you have all the base hardware.
What you need is to burn more fuel and add more air, and to tune for the new air to fuel ratio.
My guess would be that you could pick up quite a bit more horsepower with
NEED
-larger turbo
-tunable ecu
probably need
larger injectors
larger exhaust
may need
larger fuel pump
larger intercooler/piping
Old Dec 27, 2016
Re: 2016 Civic Ex-T
Any good advice ?
Races were on i10
yes
don't race on public roads.
don't drive at that sort of speeds on public roads.
there's amateur racing and track days for that sort of thing
Old Jan 13, 2017
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
Re: 2016 Civic Ex-T
Originally Posted by sdaidoji
yes
