Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Aftermarket Header With Stock ECU and O2 Sensor??
Old Aug 27, 2017
ThatDSeriesKid's Avatar
ThatDSeriesKid is an unknown quantity at this point
Can I run a aftermarket header on my 96 Civic EX Coupe with a stock ECU and a O2 Sensor? I might even install a test pipe if it doesn't affect my mixture reading.
Thx
Old Aug 27, 2017
Re: Aftermarket Header With Stock ECU and O2 Sensor??
Yes. Usually.
Old Aug 27, 2017
Originally Posted by ezone
Yes. Usually.
so it won't limit my power? Or give me a false reading? My CEL is already on so Idc about that.
Thx
Old Aug 27, 2017
Why is that?
Old Aug 27, 2017
Heat sending unit
Old Aug 27, 2017
Originally Posted by ThatDSeriesKid
Heat sending unit
A whut?
Old Aug 27, 2017
A whut?
some people call it a temperature sending unit. It's bad so my light stays on, haven't bothered changing it yet
Old Aug 27, 2017
So you don't care about the engine running correctly in the first place, but you want to slap on a header?
Reference: running at all ≠ running good
Old Aug 27, 2017
Like, literally it runs fine, no misfiring, no power loss, no overheating, I don't think it's all the way gone yet.
Old Aug 27, 2017
That's because the ECM can substitute a backup value for a failed ECT just so the engine can stay running. That doesn't mean it runs like it should.
running at all running good
Fix the ECT code ($25ish for a sensor, have you even bothered to check it out?) and it will probably gain you more performance and driveability (and gas mileage) than any bolt on "performance" junk.
Old Aug 27, 2017
it's a coming, it's a coming. Sooo. Your not a fan of performance headers? I have scanned it on my friends scanner (as far as checking it out physically...no" I'll probably fix that when I do my header install tbh.
Old Aug 27, 2017
So... for all you know it could just be unplugged. SMH
I'm a big fan of keeping a car running the way it's supposed to run.
"Performance" depends on your definition of "performance".
Old Aug 27, 2017
as being one who does his own repairs because I am mechanically inclined. There are no unplugged wires, sensors, or harnesses. I looked over my engine thoroughly, and there was nothing unplugged, or any wires with cut coating exposing bare wire. What I mean by performance, is actual performance parts, not that eBay crap that is like $120, DC Sports, Apexi, Greddy, etc
Old Aug 28, 2017
Colin42's Avatar
Well if you care about "actual" performance then a header is going to do **** all besides look better than the stock manifold
