Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Stage 1 cams? For 97 Civic Ex Help?
Old Apr 24, 2015
Tybonater's Avatar
Tybonater is an unknown quantity at this point
Hello forum people i am new to the civic scene always been into cars have basic level of mechanics but dont really understand alot of the performance stuff anyways I have a 1.6 SOHC Vtec i believe it a D16Y8. So im looking to get a camshaft figured I would get a stage one been doing some research and have found that they dont require much changing rather then just the cam i think lol.
i was looking at the crowner stage 1 . what are your guys thoughts am i on the right track?
I dont know if that cam will take away the vtec kick in lol? or what and is there anything else i should replace while i got that part of the motor opened up any advice is welcome knowledge is kowledge good or bad in a sense thank you hope to get some answers
Old Apr 24, 2015
mikey1's Avatar
Re: Stage 1 cams? For 97 Civic Ex Help?
i never really advocate "performance" add ons for these cars,
however,
i feel a cam would be useless unless you installed a header/complete exhaust system and intake first, you should get these done before the cam,
Old Apr 24, 2015
Tybonater's Avatar
Alrighty cool and when in switching out the cam what else could I do while I'm in there and also how much power can expect from a cam install stage 1
Old Apr 24, 2015
mikey1's Avatar
that depends on what has been done previous, but you might as well do all you can while your in there.....
- timing belt
- timing belt tensioner
- water pump
- cam seal
- crank seal
Old Apr 24, 2015
Stock 99's Avatar
I did some reading on the subject last night and some people who had done it said not to bother because the gains were no greater than the stock cam. I always thought there was some gain to be had from doing this but I guess it's only the 7th gen that see the benefits.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
cloudguy
Apr 28, 2015 05:02 AM
Myredjonda
Apr 14, 2015 07:00 PM
thesushiboy
Apr 12, 2015 07:40 PM
