Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Exhaust Manifold DIY ??
Old Jun 10, 2013
sekhonjatt's Avatar
sekhonjatt is an unknown quantity at this point
Hey guys, I was planning on changing the exhaust manifold on my 1999 honda civic HX as i have a huge crack on it. But i had couple questions to ask. Since i am a newbie in mechanical repairs, I was wondering if i can get some DIY to do this by myself. I tried looking it up on this website but could not find one. Or if someone can explain it to me how to do it.
I know there are like 8-9 bolts where the exhaust manifold connects to the bottom front side of the engine; so besides that is there anything else i need to unbolt?
ps. my car has cat converter on the exhaust manifold.
Thank you for your help
Old Jun 10, 2013
Re: Exhaust Manifold DIY ??
I'm pretty sure it's easier than changing your oil.
Remove o2 sensor(s), 5 fasteners to the head, assuming 2 to the next pipe. Replace gaskets along with manifold. Doneski.
Old Jun 10, 2013
BlueEM2's Avatar
Whachya lookin at?
It's easy until it goes wrong. Get lots of penetrating lube and do everything you can not to strip the crap out of the nuts. Also, have a hacksaw ready in case you have to cut them off with a couple spare studs just in case. This can get ugly If it goes smoothly though yea its super easy.
Old Jun 11, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
It goes smooth until you realize that the past 150k miles with hot exhaust and things rusting has practically welded the thing on. Find a breaker bar because I could not get the one off my old car with a normal sized ratchet.
Old Jun 18, 2013
sekhonjatt's Avatar
Thanks alot guys for the help. The bolts down at the cat were a pain in the *** to break them loose as they were rusted like a bit** ..
Also I want to ask, I put my old gasket back in since the one i bought ( from 1A auto) was made of cheap aluminium which looked like you can bend that thing easily. My old gasket was slightly rusted so i cleaned it and put silicon all over it and put it back on it. So do you guys think i should have put a new one or i made the right choice by putting the old one back on ??
Old Jun 18, 2013
That's all the gasket is suppose to be: thin and metal, likely double layer. Easy to bend. You're not supposed to use silicone or anything to help seal the gasket.
You should have used the new gasket.
Edit: for comparison sake, here's the Honda OEM one I'm gonna put on my car
And to show how thin it is
Old Jun 19, 2013
sekhonjatt's Avatar
The new gasket of mine looked exactly the same as the OEM. It just seemed a little brittle thats all. But thanks for the tip. I will change it tomorrow.
tuvok
Aug 28, 2015 10:04 AM
cukaracha
Aug 27, 2015 02:02 AM
bhollie
Aug 12, 2015 09:58 PM
PierrePierre
Aug 12, 2015 02:42 PM
hayden55
Jul 8, 2015 11:38 PM
