Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Should i decat my 99 civic?
Old Aug 9, 2012
Jordan94t's Avatar
Jordan94t is an unknown quantity at this point
should i remove the catalytic converter in my civic i have been told its a good upgrade to do and if so what decat down pipe should i put in ?
Thanks by the way im new to this...
Old Aug 9, 2012
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Re: Should i decat my 99 civic?
what engine do you have and what mods have you done? Where do you live?
Old Aug 9, 2012
Jordan94t's Avatar
its a standard 1.4 ej9 and i have done no mods and i live in dublin
Old Aug 9, 2012
^Warranty voider
eh itll save you a bit in fuel consumption but thats about it. petrol I assume?
Old Aug 9, 2012
most of us have no idea how is the emission control in ireland, so be careful and read the laws before taking cat out. (edit: thinking about, better make sure that this portion is actually serious )
also, get some mouse traps since you not going to have a cat anymore.
reminder that engine will never "purrrr" anymore after the cat is gone.
Old Aug 10, 2012
^Warranty voider
seriously LOLing
x2 check emissions laws. i live in flarda, we dont have emissions or none of that california global warming rubbish so i get away with it. I use one for autocross as street modified requires you to have one. but on the street i run a resonated test pipe i got on ebay for $25. if you can get away with it, it should give you a small mpg (liters per kilometer in your case) boost especially if it is clogged. dont expect miracles though.
Old Aug 10, 2012
Jordan94t's Avatar
thanks lads and i dont care about the emissions just wondering if i should do it or not and i think i will thanks for all the help
Old Aug 10, 2012
well, be sure to check for ECU reactions to the lack of cat. Defouler was the name?
It might not react well, not sure of the 6th gen, but the 7th gen have computers that are smart just enough to know the cat is not working as it should...
Old Aug 10, 2012
^Warranty voider
im a 6th gen owner and I know our computers are dumb enough to not really care if its there. The MIL will light up but nothing a little bit of removing can't cure.
To the OP, if you dont care about emissions, then take that ****** out mate.
Old Aug 10, 2012
thanks, RR, good to know
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
