Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Ring Clamps Wont Stay Tight
Old Mar 22, 2012
513EM1's Avatar
Naturally Aspirated
513EM1 is an unknown quantity at this point
Recently got a nice little AEM short ram intake. The ring clamps that connect the hose to the vaccum line, wont stay tight, causing hesitative and unsteady acceleration. I keep having to re tighten the clamps every few days with a flat head screwdriver.
Are there better clamps out there I should be using? Its getting really annoying.
Thanks
Old Mar 22, 2012
maxtierney's Avatar
EM2ti
Re: Ring Clamps Wont Stay Tight
I use T Bolts for everything. Unfortunately, they don't come in a size smaller than 1.25". Try replacing the supplied worm gear clamp with a smooth inner ring clamp (the one that doesn't pinch/cut into the hose), and it shouldn't loosen up so easily. I replaced every clamp AEM supplied with quality ones. No problems or loosening. Try using a thicker, high temp silicone heater hose. That'll give the clamp more surface area to bite down on.
Old Mar 22, 2012
513EM1's Avatar
Naturally Aspirated
Thanks a lot, where did you get your inner ring clamps? Local auto shop?
What about the clamps that you pinch to loosen. Those would work if I found the correct size right?
And yeah ill have to replace the little hose too because the clamps they provided are digging and cutting into the hose from retightening so much.
Old Mar 23, 2012
maxtierney's Avatar
EM2ti
Yeah, I got my clamps from a local shop. The pinch clamps would work too. It's mostly personal preference, but the worm gear clamps can tighten down a bit more.
Old Mar 23, 2012
513EM1's Avatar
Naturally Aspirated
Just so I got this right, which is your personal preference? Inner ring clamps or pinch clamps?
I'm getting rid of the worm gears first thing tomorrow.
shaejb15
Sep 12, 2015 01:02 AM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 12:23 PM
jpat21
Sep 3, 2015 11:32 PM
hatch90
Sep 3, 2015 08:45 AM
