Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
Quick Camshaft Question
Old Dec 9, 2011
Rabbi's Avatar
Rabbi is an unknown quantity at this point
i am in the middle of doing my headgasket and i sent the head out to get milled, I Pulled the cam out before sending it so they would not nick my valves.
Anyway, The question is since i removed the cam, will the head's TDC marks no longer line up properly or can they be out 180 degree's?
I Did not remove the cam gear from the cam.
Old Dec 9, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
Re: Quick Camshaft Question
Your timing marks will still be in the correct location. Just make sure you put the head at TDC and the block before you put them back together.
Then they will match up perfect.
OptimisticWay
46
Oct 15, 2015 02:16 PM
breanna_17
Jul 21, 2015 04:01 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
