Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
cold ai intake
Old Sep 26, 2011
supraman1990's Avatar
supraman1990 is an unknown quantity at this point
cold ai intake
i have a 1999 honda civic LX (wanting/wanted an ex after i found out there was a better model) anyways, im wanting a K&N cold air intake, i already have a regular K&N air intake but im wanting a cold one, is it even possible? or so i have to deal with AEM or injen? and if i do which is a better brand?
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
I have an Injen cold air and love it. Do you not like your k&n intake or do you just want a cold air intake?
Old Sep 26, 2011
MindBomber's Avatar
Live for the Twisties
Re: cold ai intake
Why do you want a cold air intake badly?
In reality short rams usually perform better and are louder than any CAI.
Old Sep 26, 2011
Re: cold ai intake
after a while having my K&N it sorta gets.... blah.... (boring) if i could fit a cold air K&N i would be happier. on top of that i know K&N is the best air filter i just want cold air intake but i looked up places even the K&N store and had no cold air intake... so i might just get AEM or injen but i dont know which is a better brand
Old Sep 26, 2011
Re: cold ai intake
really? i thought cold air was better than short ram
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
That's the perception, but it's not true. The extended length of the pipe actually restricts airflow and increases the temperature of the air higher through the increased amount of time it has to heat soak. If you want to upgrade your intake get a composite one, like a password jdm cf one on a plastic one.
Old Sep 26, 2011
Re: cold ai intake
so.... all in all forget getting AEM or injen? (also i found this on another site)
"the reason colder air is better for the car is this:
1) cold air is more dence, hence hot air rises cold falls.
2) this dencer air means there are more air particals per square inch (pps)
3) therefore pulling in one pound of hot air will give your engine (estimate here) 30,000 particals of oxegen to burn inside your engine.
4) pulling the same pound of cold air into the engine will give your engine upwards of 50,000 particals of oxegen to burn.
5) more oxegen = faster burning combustion in your cylenders.  fire/explotions need oxegen to burn.
6) if i missed something someone say it please."
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
The affect air temperature has on performance is totally correct, but doesn't directly apply to CAI.
The air temperature is typically higher entering the throttle body on cars with a CAI than other types, because the aluminium intake tube absorbs heat and passes it onto the air travelling though it. A shorter intake tube allows for less time for heat to transfer from the hot tube into the air, resulting in lower overall temperatures. The best intakes are made of plastic to almost completely negate heat soak. Look at how Spoon offers drop in filters instead of complete intakes and how Mugen intakes are plastic, they're the best companies out there and they never produce metal intakes or CAIs.
Old Sep 26, 2011
Re: cold ai intake
thanks bomb, ill try and look up short rams (cuz on top of the K&N i have is a LONG plastic tube that... tbh i have no clue why its on there besides keeping dirt from getting in the air filter bay)
Old Sep 26, 2011
Re: cold ai intake
lso here are some brands (that i can choose from and ones that can fit my car)
weapon R
Injen
AEM
hurricane
kamikaze
mugen (too expensive for me)
and option racing
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
That all makes sense about the tube getting hot and the air getting hot because it is traveling a longer distance. But after your engine bay gets hot from the engine your short air intake will be sucking in hot air from the engine bay. Wouldn't it be better to suck in cold air from outside the engine bay even though the air has to travel further? I would think that the colder charge of air traveling further would be better then a hot one traveling a shorter distance? So a CAI that is plastic would be ideal I would think? That way the tube wouldn't get as hot and the air charge would be cold?
Old Sep 26, 2011
Re: cold ai intake
you mean cold or cool?
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
The difference in air temperature between the pick-up points for a CAI and a short ram isn't extreme, especially if you don't have an header releasing more heat into the bay. There's also the consideration that the length of a CAI tube restricts airflow by forcing it to travel further and through a series of bends.
I haven't seen a plastic CAI, but you could make one out of plastic high temp tubing. Lots of people have made short rams out of standard plumbing pipes and they work well, so in theory a CAI could be made as well. I'm going to use this stuff to make a set of brake cooling ducts, but it could be used for an intake tube.
https://www.pegasusautoracing.com/gr...roupID=AIRHOSE
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
Ok, that makes sense. Thanks for the clarification MindBomber! I have a friend of mine that made a CAI out of PVC and it works great. On a cold night you can really feel it!!That stuff will be good for a brake cooling duct!! Wouldn't the perforations in it make it a bad choice for an air intake? The air would get disturbed because it's not smooth on the inside?
Old Sep 26, 2011
Re: cold ai intake
*cough cough* i know were learning wonderful stuff from bomber lol but i honest am too lazy to make home made air filters, so out of the list below i made which is the best brand to go with? (ill send a link on where i got these) my car is a 99 lx civic
http://www.andysautosport.com/honda/...t_ram_intakes/
Old Sep 26, 2011
Re: cold ai intake
and no im not trying to be rude... so if i am being rude sry
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
Perforations would definitely slow air velocity, but I think some of that specific tubing is actually smooth inside. That's what it looks like at least.
well, if you really want to know.
Best is ARC $920
http://www.andysautosport.com/honda/...m_intakes/arc/
Second best is Mugen $900
http://www.andysautosport.com/honda/...intakes/mugen/
Old Sep 26, 2011
Re: cold ai intake
Best is ARC $920
its a 4 door civic Lx, not 3 door (and tbh 3 doors look.... ugly... unless with a good exhaust system) mugen is too expensive for me, ARC isnt that close to "home made", and on top of that im looking for less than $300 for an air filter
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
Your not being rude.
this is the one I would get if you can find it for the LX, they only have it for the Si on this site.
http://www.andysautosport.com/honda/...i00133308.html
Or this one.
http://passwordjdm.com/PasswordJDM-D...2591C1306.aspx
Old Sep 26, 2011
Re: cold ai intake
LX doesnt fit those, i already looked on K&N store and it only has the flat one (which i have) so im moving to another brand that actually fits but moves outside the air cabin, and so far the list i showed you (and the brands i listed) show the ones that do fit outside the air cabin. im just wanting one with lowest maintenance but highest performance HP added
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
Yea the one MindBomber says would be your best bet. It's plastic so it won't absorb heat and it's a short ram air.
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
You have the best one our going to get!!
Old Sep 26, 2011
Re: cold ai intake
question is, does it have the same reputation s K&N?
Old Sep 26, 2011
95TYPE-R's Avatar
95TYPE-R is an unknown quantity at this point
Re: cold ai intake
I'm sorry I know this thread is about finding you a ln intake but I have a question, what are some of the best throttle bodies and intake manifolds I can get for my b18c5. Its the stockstuff now
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
Yes Password is a very good company.
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
Make a new thread if you want to go deep into the issue, but..
You already have a $5000 engine, the stock parts are already better than many aftermarket b-series parts.
Old Sep 26, 2011
Re: cold ai intake
you lost me gol, what are you talking bout?
Old Sep 26, 2011
Re: cold ai intake
uh... i have a question there, arent ugrades to a normal 5k engine better than keeping it stock?
Old Sep 26, 2011
GolNat's Avatar
Prelude Owner
Re: cold ai intake
You quoted me saying that the intake MindBomber found you would be best and you asked if they have a good reputation like k&n.
Old Sep 26, 2011
MindBomber's Avatar
Re: cold ai intake
Sure they are, but you need to consider that there are many aftermarket b-series parts based off of the stock b18c5 parts, that's how well they perform. Making the range of parts available that will outperform stock much slimmer, more expensive and generally less effective since there's room for improvement.
