ACT Clutch / Fidanza Flywheel COMBO
Old Apr 10, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Hey All...
I want to get this but I am not really sure if it's a good deal. What do you think?
http://www.groupbuycenter.com/buy.aspx?id=9593
Peace!
Old Apr 10, 2003
Bartkat's Avatar
I suppose if you already had your engine built up to produce lots of power, this would be good to add.
Old Apr 10, 2003
RoBBUsaF's Avatar
what about i/h/e and kms manifold?
Old Apr 10, 2003
RoBBUsaF's Avatar
what if i had i/h/e and kms manifold?
Old Apr 10, 2003
Bartkat's Avatar
I don't think you'd need it unless you had turbo or nitrous. Just my opinion.
Old Apr 10, 2003
RedDragon333's Avatar
bartkat its right your not producing the amount of power that would utilize those products.
Old Apr 10, 2003
RoBBUsaF's Avatar
I guess I will get it after I get all my N/A work done by KMS... =(
Old Apr 10, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
After triple checking with my honda dealer this afternoon, I will be ordering an ACT HDSS Clutch with their 11.9lb Street Flywheel in about a week. Check out http://www.lakeeffectperformance.com for some good prices. AFter 26k miles my clutch is even more tired than when it was new. I need something with a bit more bite on takeoff and a bit more feathering capability and the flywheel will help with freeing up some revs. I am looking forward to it. Anyone who has driven a true performance car knows what a clutch SHOULD feel like, not what our econobox clutches feel like...
even though it won't ultimately help performance, it sure will make my car more fun to drive....
Edit : as a side note, this is the same setup AdamOSU has on his ride and he has a good review of it on the boards here
Old Apr 10, 2003
RoBBUsaF's Avatar
Sounds good. Tell me how it works out!!
Old Apr 10, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Or if you have the $$, you can get a JUN ultralight flywheel, like me As this product is identical to the one for the earlier civic, it was the 1st MOD JUN used on their 2001 civic.
Call them for it (562) 424-7828
My set up is a ACT XTSS w/ a JUN ultra light flywheel And boy is it SWEET!
Old Apr 10, 2003
how much we talken here for your setup?
Old Apr 10, 2003
Da2K1's Avatar
you can shop around & get it cheaper, but i got the flywheel for $450 & the ACT clutch for $ 350.
Agreed a stock clutch han handle more than an NA engine will put out (w/ o NOS) but it will give you quicker shifts due to the reduced marcell & stronger pressure plate. It's also gives you way better feel while shifting (knowing the engage/ disengagement point allows you to not depress the clutch more than required, resulting in smoother, more consistent shifts)
OptimisticWay
46
Oct 15, 2015 02:16 PM
Scout1
Oct 5, 2015 01:33 PM
tommycanada
Sep 5, 2015 04:59 PM
JetsterDajet
Aug 15, 2015 08:07 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
