Finally a DIY on the 4-1 racing header with tons of pics.
Old Oct 14, 2002
  #61
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
do you want a close up on the front, or what exactly are you looking for?
Old Oct 14, 2002
  #62
Desi's Avatar
Desi is an unknown quantity at this point
Quote
[hr]Originally posted by: NBPCivic
do you want a close up on the front, or what exactly are you looking for?[hr]
i want a pic looking straight down on the header. i wanna see if the motor mounts or the space btween the header and the bumper are the same in the ex auto and ex 5spd. thanks btw.
Old Oct 14, 2002
  #63
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Desi, does this help at all?
5-speed:
Automatic:
The header fits a lot better on the auto than the 5-speed since you dont need to do as much shaving..... Its also a little tighet fit in the auto, but it works out just fine
Old Oct 14, 2002
  #64
Desi's Avatar
whosyourdaddy, thanks a lot man. that helps alot. i just wanted to see the motor mount on the left side of the header and the alt heat shield. there doesn't that much of a difference, just a little.
Old Oct 15, 2002
  #65
trevor's Avatar
trevor is an unknown quantity at this point
Very nice job bill. Very nice.
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 19, 2002
  #66
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Old thread, but just an update...I just installed the 4-1 race w/high flo cat on an 01' ex coupe. Install took 2hrs with air tools and there is no need to shave the motor mount. I used a drop chain to anchor the engine (next to the altenator just under the head) and removed the whole motor mount. Header went in with no other disturbances and the mount went right back in. This is much much better than shaving half of the mount off and sacrificing 1. warranty, 2. integrity of the mount. So if you have the means to pull the mount, it's worth the extra 10 minutes.
Just an FYI.
P.S Very nice gains, especially on high end. No noticable loss in low end torque.
Friday: APEXi N1 catback...
Old Nov 20, 2002
  #67
Mark4124's Avatar
Mark4124 is an unknown quantity at this point
Can the DC Header be installed into the LX Coupe? Are any modifications required to accomplish this, ie a pro cat? Also, can you turn off the check engine light by disconnecting the battery for 5 minutes? I know you can do this with other modifications that you install so as to reset the computer. Of course if you totally skew the cat returns, I suppose you can't reset the computer to mollify that. Where did you guys obtain this HP header? I did a search for it online and I can't find it. Well, I live in New Hampshire, so maybe I will get it. We have like absolutely no emissions testing whatsoever. Your supposed to have a cat if you have a car above 1980, but thats about it. Thanx for any help guys. -Mark
Old Nov 20, 2002
  #68
xblkcivicx's Avatar
Quote
[hr]Originally posted by: Mark4124
Can the DC Header be installed into the LX Coupe? Are any modifications required to accomplish this, ie a pro cat? Also, can you turn off the check engine light by disconnecting the battery for 5 minutes? I know you can do this with other modifications that you install so as to reset the computer. Of course if you totally skew the cat returns, I suppose you can't reset the computer to mollify that. Where did you guys obtain this HP header? I did a search for it online and I can't find it. Well, I live in New Hampshire, so maybe I will get it. We have like absolutely no emissions testing whatsoever. Your supposed to have a cat if you have a car above 1980, but thats about it. Thanx for any help guys. -Mark[hr]
Dc has a shorty that will bolt on about 0 gains, shorty's are worthless...i suggest the HP personally for the 7th gen. 6th gen i would say DC, they make an awesome header for those cars. Anyway, you will need to reset your ecu (as you do with ANY MODS). DONT!!!! disconnect the battery cable, pull the F.I ECU fuse in the engine bay, on 01 ex's its a 15Amp fuse. (this will save your radio settings, etc etc) pull it for a few minutes, start your car and dont touch the gas, you can turn on all your accessories(per acura head technician) i.e lights, highbeams, turn signals, heat/AC etc anything accessible from the drivers seat, you will notice your rpm's fluctuate...let it idle 10 min, shut it off, turn it back on for a second, shut it down, fire it off and your good to go...i got my hp header from nopionline.com it was 260 shipped with hi flo cat. now this is a good deal w/ cat cuz it's like 200 for just a random tech cat. The hi flo cat looks like a cat, but inside there's no honeycomb like the stock one...
Old Nov 21, 2002
  #69
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
n/m
Old Nov 23, 2002
  #70
circa1985's Avatar
circa1985 is an unknown quantity at this point
What brand header was used on the DIY? Was it hand-made, or a name brand like Injen?
Sorry if its been said, but I couldn't find a definate answer.
Old Nov 25, 2002
  #71
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: circa1985
Sorry if its been said, but I couldn't find a definate answer. [hr]
It's the same as the HP header. HP did not create that header. They just put their logo on it and sold it. The company that actually owns it is unknown.
Old Dec 10, 2002
  #72
rino's Avatar
rino is an unknown quantity at this point
quick question, how does it affect the sound. Does it make it sound more ricey. Personally I like the deep sound my exhaust has and dont want it to sound too ricey.
Old Dec 11, 2002
  #73
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: rino
quick question, how does it affect the sound. Does it make it sound more ricey. Personally I like the deep sound my exhaust has and dont want it to sound too ricey.[hr]
It'll just make your exhaust system louder.
Old Dec 17, 2002
  #74
Logikz's Avatar
Logikz is an unknown quantity at this point
Yea, im getting this setup as well, and am hoping it will give my exaust a bit more strength for lack of a better word. Ive got a Skunk2 Mega-Power full cat-back, and it sounds nice, but it just seems like its too weak sounding. I dont really know how to describe it, just sounds like it being restricted. Hopefully this will fix it.
Old Dec 19, 2002
  #75
xblkcivicx's Avatar
It will definitly free up any restrictions on the exhaust side for you =) give you a little bit of a deeper rumble aslo.
Enjoy!
Old Jan 4, 2003
  #76
tAkTicS's Avatar
tAkTicS is an unknown quantity at this point
i installed my hp racing header tonight and i did NOT need to shave my motor mount. i have a lx 5-spd.
however it does rattle against the part of the motor mount that connects to the frame (the black part) so i will probably cut that a little tomorrow. but that part of the DIY with the hacksaw and shaving off the silver part of the mount in order to get the header in wasnt necessary.
Old Jan 4, 2003
  #77
euJin's Avatar
euJin is an unknown quantity at this point
wsup peepz, my brother PaCiFiKbAllA has an 01' Ex Coupe and iz gonna get the Hp Race Header soon...he already has the Apexi N1 Catback (after a long wait) and he is gonna take his car to a dyno shop in Sacramento and get it dynoed (Motorsport Dynamics). I know he can't wait to hear the loudness of the N1 wit the header and high flow cat...the dc sports shorty he got was a waste of money i wouldn't recommend anyone gettin' the dc shorty header...it sucks azz...anyways just hollerin' at yall...any questions about the N1 or for PaCiFiKbAllA pm him...latez!
Old Jul 31, 2003
  #78
Woodster's Avatar
Woodster is an unknown quantity at this point
Awesome DIY man! I will be getting a car soon(yes, im only 14, not even legal to drive. Im going to be getting a 92-99 civic coupe or hatch, i plan on puttin a sri on it, new exhaust, header, new wheels(nothing above 16), and a few other things, no rice though! ANyway, thanks for the diy man, ill be lookin at it alot.
Old Jul 31, 2003
  #79
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
xblkcivicx,
where exactly did you get your header w/ high flow cat? how much?
When people talk about cutting the motor mount, is it just to allow easy installation? Is there contact with the mount when the header is installed and the engine's running?
Thank you,
Terry
Old Jul 31, 2003
  #80
Woodster's Avatar
From the look of those pics it just looks like you need to cut the motor mount for installation. One of the guys on this post said he got like a cherry picker and removed that engine mount while the cherry picker was holding the engine in place, then he installed the header and replaced the engine mount after the install was done. I have no idea though, i would just rather cut some off of the motor mount than remove the mount and then reinstall it though.
Old Dec 4, 2003
  #81
Kore's Avatar
Kore is an unknown quantity at this point
I guess it all depends on what tools you have and how much time u want to spend on the install....
Where can i buy the HP R. Header and the Cat... any sites?
Old Dec 4, 2003
  #82
C2i0v0i1C's Avatar
SuperMODrizd
cutting motor mounts........
Old May 31, 2004
  #83
OverTheTop's Avatar
OverTheTop is an unknown quantity at this point
Thanks everyone
Old May 31, 2004
  #84
Jodster's Avatar
Post Whore General
I just read the first page... so BLAH.. i don't care what the rest of you said.
YOU DO NOT NEED TO SHAVE OR CUT **** ON 03'S.. I don't know if it's different on 01's and 02's but i just got done putting mine on and i didn't shave or cut a damn thing.
I have two-three inches clearance from the motor mount.... so, if my header hits my mount.. there's a problem.
I pulled the mount, threw it up there....... snapped a bolt......and tried to pull that bolt out until my hands bled..... now here i am.. bleeding hands and a header on a car that i can't drive. WEEEEEEEEEEE
But as i said before, I didn't cut ****.
If you want a picture, tell me and i'll take one.
Old May 31, 2004
  #85
Jodster's Avatar
Post Whore General
^^^^^^^ That's prod.... i'm lazy, bleeding hands.. don't feel like logging out
Old May 31, 2004
  #86
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
awesome awesome!!!!
Old Jun 1, 2004
  #87
d17apimpin's Avatar
d17apimpin is an unknown quantity at this point
where can u find the header(as far as a site.), and i have a 03 EX coupe will i have to shave the motor mounts on mine as well and does the header just come as a header. Becuz i already have a resonator and a full Greddy EVO cat-back.
Old Jun 1, 2004
  #88
Nick's Avatar
Formerly 2blu
This thread is old as hell
Old Jun 1, 2004
  #89
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
thats right, me right here me 280 shipped!!!!!!!!!!!
Eddie
Old Jun 1, 2004
  #90
d17apimpin's Avatar
i already have a resonator, will I have to get rid of this one to run the DH header or not?
