Aem Pulleys And Unorthdox Pulley
Old May 28, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
i currently has installed the aem tru power pulley kit.. it comes with power steering and the alternator pulley...and there's one more pulley i need to change...and that's the crank pulley..but the only thing is aem does not have it only unorthodox have it..
have anyone try combining them together..
like power steering=aem
alternator=aem
crank=unorthdox
and is this a good idea? or a bad idea..thanks...and for the aem pulleys..
i feel the gain..cause the rev it faster
Old May 28, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
the combo will be fine, but as u know, pulleys have a tendency to drain power in other aspects... such as interior/stereo power... i think you're main concern should be whether or not to actually install a crank pulley, not to mention the Camgear. i've heard they have a lot of wear-n-tear on the engine, and shorten an engines life dramatically.... just throwin out a few ideas...
Old May 28, 2002
CapYoda's Avatar
Escaped Convict
from reading some other thread, I'm not too sure if you can match the crank pulley with those pulley..
from reading orthodox's website, they dont suggest undriving the accessories pullies too much..
Old May 28, 2002
RunawaySoul's Avatar
RunawaySoul is an unknown quantity at this point
I was doing some researching into this myself. If you search for unorthodox, you'll come across this thread about how crank pulleys are perfectly balanced and how it's not a good idea to replace it, although you'll get some gains with this pulley replacement more so than the other pulleys. It was enough to convince me to not change.
Old May 28, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
<< the combo will be fine, but as u know, pulleys have a tendency to drain power in other aspects... such as interior/stereo power... i think you're main concern should be whether or not to actually install a crank pulley, not to mention the Camgear. i've heard they have a lot of wear-n-tear on the engine, and shorten an engines life dramatically.... just throwin out a few ideas... >>
they dont drain the power they are lighter and the aem alternator pully has a much larger diameter. this means that it takes longer to make one full revolution, thus less power generation
Old May 28, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
so its not a good idea to do any of the pullies cause i was thinking about getting the entire package from unothodox racing; including the p/s, alternator, and crank pulley. So am I better off leaving my stock pullies on or actually getting these. Also, im not into that car audio stuff so it doesnt really matter to me if my sound system gets less power or not.
Old May 28, 2002
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
the crank pulley is only used for the track ... it is not recommended for daily driven cars ....
Old May 28, 2002
GreenVenom's Avatar
GreenVenom is an unknown quantity at this point
Someone had posted in an earlier tread that by mixing aem with unorthdox that it was impossible b/c the unorthdox rotates different or something like that can't really remember though. but i do know that changing the crank pully is wear you will get most of your power increase!!!!! not sure how it will wear on your engine though!!!
Old May 28, 2002
GreenVenom's Avatar
the tread was crank and pully's i think and it was boost that said it check it out cool!!!!!!
Old May 28, 2002
Turtle's Avatar
Turtle is an unknown quantity at this point
If you were to mix the AEM pullies witht he Unorth crank pulley, the accesories will be highly underdriven. In theory, you will notice a huge difference in revving up and hp wise, but you will also notice a difference in light dimming and more effort in steering the car. The Unorth alt and ps pulies are just lightened pullies. THey arent underdriven at all. I am just thinking about getting hte Unorth PS pulley just for the looks. Just my 10 cent becasue my 2 cent is free.
Old May 28, 2002
1028CiViC's Avatar
alrite..thanks for the idea..
but which one is more gain..
the crank? or p/s and alternator..
Old May 29, 2002
Blown's Avatar
Blown is an unknown quantity at this point
The crank would give you the most power gain, just remember, by saving weight on rotating mass on rotating engine parts, you get power. The crank is the heaviest pulley, so, would give you the most gain. Before you actually think of getting the crank pulley, take a look at how hard it would be to take off! I did and that instantly changed my mind.
Old Sep 3, 2002
Martin's Avatar
Martin is an unknown quantity at this point
Wouldnt removing and replacing the crank or all the pulleys be worth the gain to have fun riding ?
I am seriously looking for torque gain at idle starts, but will changing the crank only improve enought so I wont be changing m minde like many members in here ?
Old Sep 4, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
I am not into stereo, so it is safe to just get the AEM pulley kit or it is still not safe and wear the engine down?
Old Sep 5, 2002
orso's Avatar
orso is an unknown quantity at this point
i have never heard of engine wear because of changing the accessory pullies. i would do it if i had the money. you shouldn't have any problems.
Old Sep 8, 2002
bo0sT's Avatar
bo0sT is an unknown quantity at this point
I know for a fact, from EXPERIENCE.. that you CAN NOT mix match pulley sets. either stick with the two AEM gave you.. or buy the full set from unorthodox. The pulleys are different sizes, weights, etc when made my different companies. You will screw up your timing, and screw yourself. Pick a set.. and stick with it. I recomend UR.. the entire set is just a few pounds.. and most of the gain will come from the crank pulley.
Old Sep 8, 2002
1028CiViC's Avatar
That's rite, I don't think it's a good ideal to mix and match. Right now i am using Aem's and i have run a 200 watt amp with a 1 10" sub and it's still ok. Ppl who are interested in getting pulley's i would recommend u to get the the unorthdox, because this set of kit comes with 3 pulleys..and Aem only come with 2...and u can't mix and match..
cause the belts don't fit...
Old Sep 9, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
I am using the UR Ultra SS (3 pulley set) and like it very much. Most of the underdrive affect on the UR set comes from the crank pulley and weight savings. 3 lbs vs. 12 lbs. The PS and Alt pulleys are almost the same size as stock. Your engine will rev quicker and have less engine braking. This is especially noticable at higher speeds.
Old Sep 9, 2002
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I know, I know...alot of people say OBX is junk, but they also have a 3 peice set, crank, steering and alternator. Do you think there worth getting, and I should probably look into what they underdrive?
Old Sep 9, 2002
Booohahaha's Avatar
BAD MON
sure if u trust OBX go ahead and get it
Old Sep 11, 2002
1028CiViC's Avatar
So no one has did it..Mix and match...
How much is just the unorthodox crank it self..if i really do get it..
i will need new timing belts..
Old Sep 11, 2002
FamilyMan's Avatar
Quote
[hr]Originally posted by: 1028CiViC
i will need new timing belts..[hr]
Timing belts??? Here is the website for UR: UR Racing
Old May 15, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
crap! i bought the aem pulley set and an ur crank pulley thinking it would be ok.... does anyone have this combo to this day because this thread is kind of old... also, did the belts that came with the aem pulley set work with the crank pulley as well?
Old May 15, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Damn dude, this thread is very old. I don't know if they fit and I haven't heard of anyone having the combo and working. you should just get all unorth for the uniformity of everything and it will work better. Hope everything gets worked out for you RoBBUsaF.
Old May 15, 2003
RoBBUsaF's Avatar
anyone want to buy aem tru power pullies? they are red and have never been used... =*( belts included...
Old May 15, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
I can't recall the thread i posted in about the crank pulley... search for the thread, I discussed harmonic balancers, crank pulleys, and the entire ur set...
From an understanding of how to derive power from pulleys, there is really only 2 effective ways to do it, and aem and ur's technologies and methodology are completely opposite on the spectrum.
Unorthodox uses an underdrive theory for their pulleys (yes the crank is the only power added, the other 2 are show, accessory, and the other) , however on the other end of the spectrum is aem's method...
Aem's method is to enlarge the pulleys, I will update, but look for the thread, i had an exact definition of its method in that thread, and it's been so long.. i will update once i get back from seeing and paying for the matrix2, yes, it was good, i was invited to the sneak preview and given a ticket for last night... i had already bought this ticket.. oh well..
maybe the aem will have seeped back in..
FAMILYMAN is correct, and all 3 of the ur pulleys eqaute to about a maximum of like 5 or 6 grams heavier than the lightest of the stock pulleys.
sorry i can't remember right now, will return with completion.
Old Nov 11, 2003
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
I know a member Macfay has did this aem pulley and unorthodox crank
but i am not sure which belt he has use.
Old Nov 11, 2003
ImportRacer2123's Avatar
K20 Member
Ack! Attack of the dead threads
Old Nov 11, 2003
RoBBUsaF's Avatar
my car is in the shop and since no one bought my pullies im having kms throw the aem ones in with my ur crank. hope it works..
Old Nov 12, 2003
K20 Member
Rob when is it due out? and what is being done to it?
