Engine performance
Old Nov 12, 2017
Rolyc77's Avatar
Rolyc77 is an unknown quantity at this point
Engine performance
Hi. I wanted to do some performance to my car and I have a couple of questions...
Old Nov 12, 2017
GolNat's Avatar
Prelude Owner
Re: Engine performance
Questions like....
If you have a 7th gen everything you could ever need to know is on this forum just about
Old Nov 12, 2017
Rolyc77's Avatar
Originally Posted by GolNat
Questions like....
First time I own a civic. I wanted to know if it's ok to put headers, cold air intake, intake, throttle body etc... On this engine. And possibly a turbo kit without really going into the engine... I would appreciate the feedback back. Thanx in advanced...
Old Nov 12, 2017
Wankenstein's Avatar
You can but just a waste of money if kept naturally aspirated. Won't add much (if any) power gains.
You can but do research and keep psi low: https://www.google.com/search?source....0.zyoUa_c0jJs
Old Nov 13, 2017
Stock engine can handle 8psi of boost. Some members have gone up to 10psi, but that's really pushing it. You'd better have a bulletproof tune.
That said, if you go turbo, your tune will make or break your setup. Crap tune, and you'll be replacing head gaskets or engines sooner than later.
Best bang-for-buck engine mod you can get for the D17 is a crower stage 1 cam. You'll get more response from bolt on mods (intake/header/exhaust) and you'll get more power from the one mod than any other engine mod.
Suspension mods is another place you'll get great value for your money. Go with reputable brands that have done their R&D. There are companies out there (most notably Raceland) that some people have gotten great results from their highly affordable coilover systems, but there have also been a fair share of people out there that have suffered catastrophic failure from the same. Budget brands like that is like playing Russian Roulette. You may get lucky or things can go south real fast.
Old Nov 13, 2017
Rolyc77's Avatar
Thanks a lot for your reply. It's been real helpful. I'll probably go that route, swapping the cam and adding the bolt one. This is my daily driver and I just want to have some fun and wake it up a bit... I'll leave the turbo out of it. I don't wanna get into the crazy running and stuff... Lol!!! Once again thanks I really appreciate it man...
Old Nov 13, 2017
Question:
Which model?
The crower cam is for the EX engine only.
Old Nov 14, 2017
Rolyc77's Avatar
Yes, it's an ex coupe...
Old Nov 14, 2017
Then, cam it! with a "m", not "n" pun intended
Old Nov 15, 2017
J-swap FTW
Old Nov 15, 2017
K20/24 Franken swap
