LX headers on EX Head?
Old May 6, 2017
RoseyEm2's Avatar
RoseyEm2 is an unknown quantity at this point
Manifold cracked, just gonna buy a new one. Can I get LX headers? Will it fit fine? In the process of doing a A2 headswap.
Old May 6, 2017
Re: LX headers on EX Head?
Removing the manifold (assembly with the cat) and replacing with a plain header will cause catalytic converter fault code P0420.
Old May 6, 2017
RoseyEm2's Avatar
Okay well I guess I'll just go to the junkyard. How would I clean a catalyst converter? Would an LX exhaust manifold fit on a EX head?
Old May 6, 2017
Another option, you could get a stock EX exhaust header and cat, along with some O2 sensor extension harnesses to relocate them.
Does your car have to pass emissions testing?
Old May 6, 2017
RoseyEm2's Avatar
Yeah it does. I just thought I'd clean it out to have a good catalyst.
Old May 7, 2017
Then you may need to figure out what the regulations are in your area and what sort of checks will be done.
Does everything have to pass a visual inspection and be strictly stock as it came from the factory?
Is it simply inspecting for fault codes, nothing else?
Tailpipe snifff emissions test?
Old May 7, 2017
RoseyEm2's Avatar
No it's none of that. I just like to clean used things. I live in Florida so it's not strict. What can you use to clean it? I know there's a mesh inside of it. Would something like brake cleaner or carb cleaner work? Or do I have to use an specific product?
Old May 7, 2017
RoseyEm2's Avatar
I'm sorry I misread what you said. Nah my car is okay for emissions.
Old May 7, 2017
I'm not aware of any viable product or method that can truly "clean" a cat substrate (that's the guts or element inside the shell) and restore lost efficiency to sustainable levels. Many products make claims, but none are guaranteed to deliver....and every good sales pitch I've ever heard was based on junk science. At best you're buying a short period of time before failure happens again.
I'm sure you can find references and videos showing various cleaning attempts that look and sound good, but no guarantees and many can cause more harm than good. There are also cheap tricks that can get around setting cat fault codes, but wouldn't pass a visual exam of your emissions systems at test time.
Re: used cat
If you can see around corners (some styles of cat) you might be able to get a light at one end of the substrate and be able to look through the substrate and see that light to determine if it may be clogged or not, but you'd never be able to tell if it will pass the computers self testing because the computer judges the cat on its ability to store and release Oxygen and that happens on a microscopic level inside.
Get a cat, bolt it on, connect proper O2 sensors.
Erase fault codes. Drive it a few days. Check readiness monitors to see if the cat monitor has run and passed with no fault code set. If so, you got a decent one.
You could try brazing the cracks shut in your original unit too, that could buy some time if it hadn't already set fault codes.
Old May 8, 2017
it will fit, but you will need to change the other pipes too, from what i understand?
EX - CAT is after downpipe
LX - CAT is in the header
you have an EX and wants to put LX? That's the opposite of what others want to
Old May 9, 2017
RoseyEm2's Avatar
No I have a LX and I'm converting to VTEC so I'm putting a EX head. Just asking what I should get .
Old May 9, 2017
Wankenstein's Avatar
Best way to clean a cat is the same as cleaning a fish..gut it.
Just don't tell uncle Sam and live in a state without emmission checks.
Old May 9, 2017
I'd say do it one step at a time.....so
For simplicity, for the moment, just reuse the manifold and cat the car has in it now. LX manifold bolts to the EX head no problem.
After you have the head and VTEC all working like you want and know it's good, then dink with changing out the exhaust as you desire.
Old May 9, 2017
RoseyEm2's Avatar
Yeah I guess I mean I didn't really care about headers I'd probably go to an exhaust shop and have them make one that can fit. I just wanted to know if the LX manifold can fit on the EX head
Old May 9, 2017
ah, OK, so then use a LX header - it will cost more for the CAT, but if EX, the wiring need to be longer to reach the O2 sensor. its much easier to use existing wiring.
Old May 9, 2017
Oh yeah it will, no problem. Pattern is exactly the same.
