MAF sensor
Old Feb 2, 2013
Civic13's Avatar
Civic13 is an unknown quantity at this point
MAF sensor
I have a short ram intake and it looks like the maf is stretching is there a longer connecter I could buy?
Old Feb 2, 2013
Re: MAF sensor
7th gens do not use a MAF sensor.
Pick a correct name or put up a pic of the problem??
Old Feb 2, 2013
Civic13's Avatar
Re: MAF sensor
My em2 01 has a maf connector on the short ram if that's not the maf what is it called?
Old Feb 2, 2013
Re: MAF sensor
It's not a MAF. How about an IAT?
Old Feb 2, 2013
Civic13's Avatar
Re: MAF sensor
Yes that's what it's called!! Is there some type of extender
Old Feb 2, 2013
Re: MAF sensor
Have you tried Google?
I don't use stuff like that, I normally have no problem with modifying wiring as needed.
If it were me, I would go to the point that the sensor pigtail (harness) comes out of the main harness, see if I can open up the main harness cover/sheath/wrap to give some more length to the wires, without damaging the wires or their insulation, and without splicing or using an "extension cord".
Old Feb 22, 2013
truefriend's Avatar
truefriend is an unknown quantity at this point
Re: MAF sensor
I HAVE THE SHortest ram....I just shoved my filter on top of the throttle body and zip tied the sensor on the filter... looks great , ran a little lean of course ..at first then it settled down ,or level off , the only thing that might be a problem is the air flow across it is not as concentrated as it would be inside the pipe...i hope its the temp. and not the speed of air that makes it work
Old Mar 29, 2013
rockstock01's Avatar
rockstock01 is an unknown quantity at this point
Re: MAF sensor
quit being a deeb. rocker tappet, hood bonnet. We all know what he's talking about, anyway now that i've ranted, I just unsheathed some of the wiring to the doohickey that comes out of the airboxintake thingamajig. i was able to get an extra couple of inches of play. (that's what she said) when i put together my hacked together air intake. As for buddy that put his intake right on top of his intake manifold, I'tried that too. didn't seem to do anything, I think i took a power loss actually. The sensor thinger didn't read right and i'm sure the intake temps were higher. when i put the pipe back on i think i got a little better bottom end. just using my butt dyno.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
