o2 sensor cel
Old Nov 23, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
o2 sensor cel
i have megan headers which delete the cat and have an angled cel eliminator on the second sensor which worked fine. but last night the cel came on so i hooked up the scanner and it says post cat o2 sensor slow response.
does this code mean the sensor is failing or something? or is it because i have no cat before the sensor?
i guess the wording is throwing me off...i would think it would say something about the converter not slow response from the sensor if it was the cat
Old Nov 23, 2011
MelJ's Avatar
Trance Addict
Re: o2 sensor cel
P0420 is the one you're thinking of. My car has that code. Well not anymore, I cleared it and I make sure the PCM doesn't run the monitors. If you have that code, it means the CAT isn't doing its job and both o2 sensors would have the same exact reading. Both my sensors work, but the CAT is basically toast at this point. I haven't had any personal experience with that, but I would think it's just failing, or getting close to it. If you know anyone with an available scan tool, you can check out the graphs for them.
Old Nov 23, 2011
pwnsauce's Avatar
Re: o2 sensor cel
i dont have a cat...well i do but its down in the catback. but like i said i have an angled o2 sensor thing on the second sensor. so they shouldnt have the same readings
jzhartman
22
Jul 23, 2015 10:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
