Finally Installed w/pics!: Weapon R Secret Weapon Intake.
Re: Ordered: Secret Weapon Weapon R Intake
hey gear, when i ordered my WR secret intake, it came wit two filter and the cleaning kit. but the label on the cleaning kit is gone, and i forgot how to clean the filter...which bottle goes first? the green liquid one or the brownish one? since you clean it often, what do you recommend the best way to get the dirt off and applying the cleaner
well i have the UNI cleaner and oil and they are clearly labeled. just test them and the one that feels very sticky is the oil. you want to spray on the cleaner first (smells bad like gas), let it sit 5 minutes, then rinse it all out with running tap water inside and out. repeat this if the filter still looks dirty. then hold the filter on its side and let the water drain off, then shake it many times to get the excess off, and finally let it dry for a few days. a week is better just to be sure its dry. then spray both sides all over with the oil and reinstall.
A descendant of 2k1civic.com
Regular air dry is important. Don't put a fan on it. You'll kick up more dust and have a dirty filter before you put it back in.
Okay I've just installed the intake I will take some pictures of my dirty engine bay with the intake installed, I did some quick ghetto-rigging to hold it up the best way for now. Later on i'll come up with a better way to hold it up.
I don't mean to thread jack pheaton, but I don't think it makes sense to make another thread about the intake. So here is my ghetto install. Please forgive the dirty engine bay (any suggestions on whats best to clean it?). Please try to be nice about my ghetto rigging.
Isn't your little clamp there going to rub the finish off?
My other concern I guess are the wires running over the pipe. Wonder what the risk of those getting too hot?
one of those tubes rubbed a big mark in my sticker and now it doesnt look as good. i doubt anything gets hot enough to matter. the engine bay is already hot and i havent had any problem in the summer heat.
also i wish they didnt change the design. i liked the older style alot better. the temp sensor was in a better spot, and the tb pipe was a whole piece no welding, and had rough surface inside to turbulize the air flow lol. too bad they never made it a dual chamber pipe either like most of the other models.
Any suggestions on how to clean up the engine bay like all of the dirt and grime? And does that clamp look lame? It actually does help hold it up a bit. Please for some feedback! Thanks alot!
its fine but may eat through the pipe after a while. just due to the intake moving around alot while driving. what i did was take a small bracket and wire tie it to the cruise control box mount and the bottom of the intake clamp. and then used a few zipties too which seem to be working.
another thing is make sure you sand down the end part of the filter that goes into the rubber tube and then wipe with alcohol. its really smooth and ive had mine fall off a few times. but after sanding it and wiping everything with alcohol, it never did again. fyi...
It showed up today!! Check it out.
Gearbox, did yours come with the bracket in the 4th picture? Is this the magic peice to fix the sagging problem? Or is this bracket something else? I haven't gotten to the install yet. I will be sure to post pics of that.
i threw that bracket away lol. its so soft, it will bend from the weight of the intake. whats that long black thing that says WR in the back?
I installed a secret weapon intake on my 00 civic ex about a month ago. You only hear it when accelerating a little hard, but it's very noticeable when you do so. Also there's a little whistle noise right before I switch gears, can be heard at the end of each gear.
If people say they don't feel power they're not very smart. Anything that lets an engine breath a lot better instead of restricting air flow makes a noticeable difference.
I'm going to do a b16a2 engine swap, I believe it'll fit when I do that later this year, but I'm also thinking about boosting. Until then SW intake gets a thumbs up for me.
and wth is that plastic tubing for?
No it's not a seatbelt pad. It's the Ram Air II kit. When I do the install I'll see if it's worth a darn. The bracket seems pretty firm, I'll see how that goes too. I think I have access to a welder, so one way or another that baby is going to be mounted on there good. Where did you get your oil kit?
ordered from weaponspeed.com i think, and they sent me the UNI brand foam oil and cleaners. very good stuff. wait you didnt get oil with yours? its supposed to come with two things (cleaner and oil) even the weapon-r kit has both. you got robbed lol, and you need the oil to use on the filter.
I was hoping to install it this weekend but this might put the plans on hold. At the very least I want to maybe do a loose fitting on the car and see what I can work out with the bracket.
We'll see what happens.
Re: Arrived: Weapon R Secret Weapon Intake *pics
The oil is not included I went through this same problem a few weeks ago, had to order the oil separate. As for finding the oil locally please note that it isn't recommended to use any other oil (like the K&N brand) on the WR intake.
Well, no luck locally. The install will have to wait for a bit longer. I'm going out to weaponspeed or something now to get the oil on the way. I'm hoping that I'll get it by next weekend so I can hopefully get this installed around family Easter time.
I guess it wont hurt waiting another week, I'm taking the car for an oil change on Tuesday, so might as well have the car running well before I install the Intake.
I went to Autozone to ask for the filter oil and the conversation went something like this:
Me: Do you have foam filter oil?
Guy: What kind of oil?
Me: Foam filter, it's treatment oil for a foam filter.
Guy: So you want oil for your filter?
Me: Yes
Guy: You have a foam oil filter?
Me: No, I have foam intake filter and I'm looking for the oil that goes on it to treat it.
Guy: Oh, ok. I know what you are taking about now. We don't sell those. If you look in those Import Tuner magazines we have, you'll find all kinds of stuff that you need in there. Or go to spoon.com.
Me: Uh. . Ok thanks..
So that was fun. I did pick up a Haynes book though (quick reference) and I figured I might as well pick up a PCV Valve. I probably don't "need" one but might as well sense I'll be working in that area of the car.
Me: Yes
"spoon.com"
sounds like a very informative conversation. you should go back and tell him you went online and it was a gourmet foods site and just watch the dumbfoundedness in his eyes.
sounds like a very informative conversation. you should go back and tell him you went online and it was a gourmet foods site and just watch the dumbfoundedness in his eyes. Registered!!
Got a question for those with weapon R intake . Do we have to treat the filter prior to install? If so why? will not treating the filter affect performance?
Gear, where did you get your oil? I'm having troubles finding it. I found a few places, but nothing from anyplace I've bought before.
lol i actually dont remember, i thought from racinglab.com but idk. been way too long. and i got a second can of oil free at the last car show i was at
too bad you dont live nearby or you couldve just come over and used mine
