My AEM Cold Air Intake
Old Jan 6, 2007
AJay1088's Avatar
AJay1088 is an unknown quantity at this point
I just had mine installed today, but I have noticed that its buzzing -- vibrating. I know this is bad for it, but I'm not sure what to do, I don't want to ruin the intake. Where do i go, and what do i ask for/say for them to fix the problem???
help
Old Jan 6, 2007
hondoer27's Avatar
hondoer27 will become famous soon enoughhondoer27 will become famous soon enough
Where is it making noise from?
Old Jan 6, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
is it rubbing up against something? open your hood and just rev it up a few times and see what's up.
Old Jan 6, 2007
TeLLy's Avatar
Yes, it's an Acura EL
It could be rubbing against the hood, or maybe strut bar if you have one. Have you checked up by the battery tray/tranny as well? Pop the hood, start the car, and pull the throttle cable to see if you can reproduce the noise.
Old Jan 6, 2007
Alpha 5's Avatar
I don't advise this! Telly this is good advise to someone that does there own work. This guy (the thread starter) paid a shop or someone to install an intake. I don't think he needs to be leaning over the engine and pulling the throttle cable. JMO
Old Jan 7, 2007
DJ GEE's Avatar
DJ GEE is an unknown quantity at this point
Slave cylinder
Look at the bottom below the battery, there is the steel line to your slave cylinder it gets pretty close to the first pipe on your intake, If so just bend it a little that if u drive manual.
Old Jan 7, 2007
TeLLy's Avatar
Good call. Let me rephrase then - have a friend tap the throttle gently while you have the hood open and are standing in front of the car without leaning over it.
ph0ng
52
Mar 4, 2003 09:15 PM
HX
Dec 22, 2001 02:36 PM
2k1civicman
Bolt-on Engine Performance
Dec 17, 2001 06:18 PM
BiGbRoWn
Nov 21, 2001 06:17 PM
