REVIEW: Weapon-R Secret Intake (pics/vid)
Old Jan 21, 2006
This is the Weapon-R Secret weapon intake for 01-05 civics with newly designed SW1 filter element. This is gonna change what people think about weapon-r products.
Well after a rough 2 hours, its finally installed! I just wanted to do a quick review of the positive and negatives as compared to other intakes I've tried out already.
PROS:
1. The intake looks sweet! polished metal with all grey mounting hardware makes it blend into the engine bay well.
2. The intake uses alot of new technology. The secondary pipe has a rough surface to promote turbulence (like what the throttle body spacer was supposed to do but better). The SW1 filter has been flow tested to outperform K&N many times. It flows more air than an open intake pipe due to its velocity stack design and open top. Finally, the overall design of the intake is improved. The temp sensor and breather hose are located away from the throttle body as not to interfere with airflow, and the pipe that connects to the throttle body allows for a smooth transition of airflow that is great for guys with a ported throttle body like me. There is also a small air plenum above the tb to allow for greater throttle response.
3. The sound it makes is very mellow and almost sounds just like my rsr exhaust. It is deep when you stomp the gas, but not your typical rice intake sound that others like aem and K&N are famous for. This is a major plus for me because most people would not even be able to distinguish the intake from the exhaust sound.
4. the hissing noise it makes on warmup and shutdown are still there, but only 1/2 as loud as other intakes. Another plus because I don't want it to sound like a vacuum cleaner under there lol!
5. As far as performance, I would say low end power is at least as good as the stock airbox, if not better. It also pulls very good in the higher rpms. No power loss at all. Best of all, throttle response when taking off from a stop is much better. This thing jumps forward immediately when you mash the gas.
CONS:
1. the intake pipe is still metal (and unpainted/anodized) so it will be getting very hot in the summer. This may be offset slightly by the fact that this intake takes up very little space and sits at the very back of the engine bay to promote more air circulation.
2. This is one of the hardest intakes I've ever had the displeasure of installing. Nothing fit the way it was supposed to! The breather hose was too small but I was able to force it on anyway. The rubber fittings had a hard time going together and on the throttle body. The temp sensor was about 12 inches too short and the wires needed to be extended. Then when I plugged in the sensor, it was loose so I wrapped electrical tape around the base to keep it in place. The bracket that holds the filter to the stock mount needed to be bent (thanks to the previous owner for doing this already). The filter is touching a harness and the fuse box. Very cramped but it fits.
3. There is no way to use the optional ram air kit without removing the fuse box.
4. The primary pipe is a bit larger than should be for this engine. Three inches compared to stock 2.5 inch. And there is no dual chamber design like weapon-r made for other vehicles from this model.
After all is said and done, the long install was worth it. This is by far the best intake I have owned. The aem sri is just crap for every reason, the K&N fipk is okay but looks dumb and makes very strange noises. The only other intake that comes close is the typhoon, but I didn't like the sound it made or the filter it came with. Overall I am very happy with this intake. Great low end and hi end, awesome sound, and amazing looks.
Now onto pics and video!!!
http://s46.yousendit.com/d.aspx?id=1...Q0QZCQ9YVP0AHF
And finally with relocated fuse box and HVS-GT installed
Old Jan 21, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
matches your exhaust manifold heatshield very well
Old Jan 21, 2006
the only thing is now there is a big hole between the battery and filter. Any ideas what to put there?
Old Jan 21, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
custom fab heat shield?
Old Jan 21, 2006
blouisgod's Avatar
Life Begins > 6800rpms
Looks great... kinda sucks though about the fitment issues you had. the design of it looks real similar to the injen sri. did you use the billet polish on the intake and the header shield? it looks blingin'
Old Jan 21, 2006
haha yea i did some polishing with mothers billet.
Old Jan 21, 2006
DDragon7's Avatar
Looks really good and different. As for the space, I would just keep it like that.
Old Jan 21, 2006
HondaKorn's Avatar
Life is better with 5lug
looks good dood!! I ordered the sw1 fitler to use with my injen sri piping...awesomeness
Old Jan 21, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
How about an intercooler charge pipe
Old Jan 21, 2006
R1Style's Avatar
Looks good homie....
after seeing your heatshield I may polish mine
btw... is the filter touching the fuse box?
Old Jan 21, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
my WR filter will be here on Monday ... woot.
Old Jan 21, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
looks pretty good in the bay
Old Jan 21, 2006
R3DL1N3's Avatar
i had posted about this intake a long time ago. i cant remember, but would it be a bad idea to put a WR filter on aem cai? i was thinking about going with the dry flow, but if this is a better filter then i might consider buying it instead.
Old Jan 21, 2006
don't get the dryflow unless you like losing tons of hp. You can get an SW1 but they only come in two sizes: 3 inch and 4 inch. so if your cai matches, then yes you can get it. And you also need their cleaning kit to put oil on the filter. I'm still waiting for mine.
Old Jan 21, 2006
ragingSPAM's Avatar
I just burnt my tongue
looks good i wanna see it on a stick
Old Jan 21, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
Very nice, I wonder if Weapon-r makes an air filter that fits my V2.
Very clean engine bay!
Old Jan 21, 2006
R3DL1N3's Avatar
the 3 inch might fit my aem. if anyone knows the aem cai filter size that might help.
Old Jan 21, 2006
Hayz's Avatar
Good reveiw gearbox I'm wantin a new intake just can't decide
Old Jan 21, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I think the AEM/Injen CAI's are the intakes that will give the most power ...
best sri in my opinion is the K&N FIPK2
Old Jan 21, 2006
vietstylez's Avatar
definately matches your polished heat shield very well
Old Jan 21, 2006
cwick187's Avatar
cwick187 is an unknown quantity at this point
I agree with gearbox, this is the best intake (for gains) that I have ever used on my car...I have had the AEM Cold Air, K&N FIPKII, Injen short ram and the Weapon-R....The WR gave the most noticiable gains on my manual...It takes time to fit it, but it's worth the extra time
Old Jan 21, 2006
eye_see_you's Avatar
let the devil out
yeap a heatshield and sneak in a turbo
Old Jan 22, 2006
05_ CivicJDM's Avatar
Great review, how much it cost you?
Old Jan 22, 2006
yuogotown3d's Avatar
yuogotown3d is an unknown quantity at this point
Looks pretty bling bling and sounds like a somewhat nice intake. Nice pics too
Old Jan 22, 2006
blouisgod's Avatar
aem cai filter is 2.75
the sw filter is 3"
Old Jan 22, 2006
R3DL1N3's Avatar
the sw filter is 3"
it'll fit if you just tighten the clamps down, right?
Old Jan 22, 2006
vietstylez's Avatar
.25" is a bigger difference than you would think, i wouldnt want to risk a 60 dollar filter falling off my cai anyway
Old Jan 22, 2006
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
GEARBOX, you see the tube dat connects the intake to the throttle body, how it is bent and crushed a bit due to the turning, will dat have any side affects, maybe not enough air goin into the body? cuz mine has the exact same situation.
Old Jan 22, 2006
ya that seems like alot. i will have my filter off next week to clean it (if the stupid kit ever gets here) and i will measure to see if the 3 inch is really that size or smaller.
Old Jan 22, 2006
its because the tube is too small. there is still plenty of room though for the engine to breathe. i'm gonna try and find a replacement but i havent seen anywhere than sells silicone tubing.
