ETD for my '04 Vic
Old Dec 13, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Question ETD for my '04 Vic
I'd like to get an engine torque damper (ETD) for my '04 Vic, which has a K20A2 in it. Does anyone know if I can use either a:
1. ETD for RSX-S
2. ETD for Civic Si
Thanks in advance for your help.
Old Dec 13, 2005
acidbaby's Avatar
The Beez Kneez
there is a thread on this but they never came up with anything...
i think there are universal kits on EBAY..
Old Dec 13, 2005
Thanks for the info. No way am I buying some junk off of eBay though. Maybe I'll have to have a custom bracket made.
Old Dec 14, 2005
kornsined's Avatar
I was actually thinking the same thing. I thought the hasport mounts would have been enough to not need a tourque dampener. I know they have different durometers in their mounts.
Old Dec 14, 2005
I think the Hasport MMs are great, and do away with the need to bu ESMMs, but there still is some engine movement that could be reduced with a torque damper.
Old Dec 14, 2005
diskreet's Avatar
i am guessing the Si one would fit before the RSX one but if you get something I am sure a metal plate or 2 custom cut/drilled will do the trick
Old Dec 14, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
I also think the Si one would fit since those probably have the closest engine bays to the em2's ..
Old Dec 14, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Ingalls has a universal one, also one for the D17 and k20A2, now the swap ive emailed um and got no responce. trying to find the same thing out.. Think i might try the d17 kit reversed on the oppisit side and see what happens. Just a thought
Old Dec 14, 2005
I emailed Ingalls and got a response stating they had no idea which version would work.
jimmy23
Aug 31, 2015 10:35 PM
derty
Sep 13, 2002 08:49 PM
2cute
Aug 6, 2002 02:55 PM
SoNiCcIvIc
May 14, 2002 03:35 AM
