Finally, an engine torque damper for the D17!!!
Old Oct 21, 2005
blouisgod's Avatar
Life Begins > 6800rpms
http://ingallseng.com/parts/93026.htm
from ingalls - its msrp is 340 though!!! wtf?! im hoping that NRG makes a knockoff soon. just and FYI
Old Oct 21, 2005
manahoonie's Avatar
i'm blind, and tired (just woke up)
but i'm not seeing anything as a focus point in this pic. poor advertising...
Old Oct 21, 2005
blouisgod's Avatar
agreed - unless you knew what it was before, the pic sucks. heres what it is.
Old Oct 21, 2005
rEkKaShInObI's Avatar
Unsalvageable
overpriced
Old Oct 21, 2005
djmota's Avatar
it says "base model" I take this to mean that it wont clear the ex ABS box or lines. too bad its so expensive.
Old Oct 21, 2005
mrDFWmechanic's Avatar
yea thats a little much for my liking
Old Oct 21, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
umm...whats this supposed to do for the car?
Old Oct 21, 2005
black05civic's Avatar
7thGen Blacked Out Crew
black05civic is an unknown quantity at this point
Reduces wheelhop I believe, but don't quote me on that. It looks like it would since it basically acts as a damper to the engine, thus equaling less vibrations and the such.
Old Oct 21, 2005
ncirom2003's Avatar
open your hood and look at your engine, have a friend get in the car. now place close attention to the engines movement while he does these things.
turn car on
put in gear (drive and reverse)
put in neutral and rev it quickly then let off
start to roll back with clutch half way out and rpm low (on 5spd)
now youll notice the engine really bounces around in there, well the engines movement is a loss of power, if you hold the engine still that power will all be sent to the tranny. hence they make this damper to greatly reduce the movement of the engine, if you made it solid youd have driveability issues. if you got this and either new aftermarket mounts or just poly inserts you would notice a better launch and less shaking under the hood. for less money you can also buy a damper seperate and probably buy just the brackets from these people, or have them custom fabbed
and it doesnt seem like it would interfere with your abs, compare some pics and decide though
Old Oct 21, 2005
ncirom2003's Avatar
here you go.
up top i circled the aluminum bracket that will mount onto your strut tower, from there you see it bolts onto the damper circled in the middle under some hoses. the other end bolts to another bracket which mounted onto the engine.
the fact that the bracket is so high up on the engine is good too, it gives more advantage to the damper through leverage and whatnot. (although on some cars they are mounted higher and may even use 2 dampers this probably wouldnt be nescessary on any d17)
Old Oct 21, 2005
Shifty's Avatar
i think that is pointless cause we dont make that much torque anyways, and for that price, thats just retarded
Old Oct 21, 2005
dre2600's Avatar
If you're willing to spend $300 and want to reduce wheel hop why not just change out your engine mounts, that'll be more effective anyways and contary to popular belief, won't make your car shake like hell.
Old Oct 21, 2005
ncirom2003's Avatar
i really think this is more of a good idea for members who are boosted or are fully built n/a, or someone who just likes to go all-out to make something the best they possibly can
Old Oct 21, 2005
i'll get it but not anytime soon.
Old Oct 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
it's not about how much torque you make ... whenever you launch your car, it's gonna jerk a lot ... this prevents (or limits) that.
ingalls tq dampner + esmm = good!
Old Oct 21, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
who makes good motor mounts for em2?
Old Oct 21, 2005
dre2600's Avatar
Yeah, I guess there isn't as much wheel hop on a 7th gen, at least not a stock one because there just isnt much in the way of torque off the line.
Not to imply that my Mazda 3 is a torque beast, but the engine mounts on that thing are so mushy the axle tramping and wheel hop from an aggressive start are irritating as hell.
Old Oct 21, 2005
pon55's Avatar
And off to the machine shop I go!
Old Oct 21, 2005
you would only need one if you pushin some serious power thats just my 2 cents
Old Oct 21, 2005
pon55's Avatar
If that will stop wheel hop (even on my stock DX) i'm all for it!
Old Oct 21, 2005
blouisgod's Avatar
these things really help on dc5s; ive driven one with the damper - every shift is firm and there is no rocking of the engine. im looking to get that taken care of with it, rather than replace my sloppy, crappy 01 trans with an 05...just not for 340 bucks quite yet. like i said, NRG should make a knock off soon, they run about 80 shipped.
Old Oct 21, 2005
ya i'll wait for knockoff
Old Oct 21, 2005
turboengnr's Avatar
DONT PANIC
i would twist those little mounting brackets into pretzels.
wtf is up with their little 1/8" aluminum mounts? Those would hardly hold up with the stock motor torqing, let alone a boosted/built d17 on slicks.
Looks like something else i will need to build. I like their actual dampner, but those brackets suck ***.
Old Oct 21, 2005
well i'm sure if you made one, we would all buy yours
Old Oct 22, 2005
turboengnr's Avatar
DONT PANIC
then i would be stuck building dampners instead of letting my shoulder heal.
Im gonna try one with some gas shocks i found on mcmaster.com <--- i love that website
Old Oct 22, 2005
cheukkin's Avatar
cheukkin is an unknown quantity at this point
dyno it and prolly gain none in our small engine imo..
Old Oct 22, 2005
turboengnr's Avatar
DONT PANIC
they do nothing for hp. they only help with power transfer to the wheels during a launch or while shifting.
Think of it this way....
you know how you get upgraded performance shocks so you can get a better launch at the track? Well this is a shock for your motor to help reduce wheel hop. It keeps your motor from twisting and hitting the limitations of the stock motor mounts.
Old Oct 22, 2005
ncirom2003's Avatar
you wont gain more power or torque but more will be put to the wheels so it will be like a gain because you arent losing it through the energy of the engine moving.
Old Oct 22, 2005
CivicsRdBest's Avatar
I'm waiting for the knockoff of the knockoff.
Old Oct 22, 2005
the ebay special? lol
Grey
16
Jan 27, 2002 11:34 PM
