D16 parts fit my D17?
Old Oct 20, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
Will parts for the D16 such as cam gears or valves fiy my D17? What other parts from a d16 will fit my d17? kthnx.
Old Oct 20, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
maybe its just me, but if you're gonna put in the work to use parts from other engines, you'd think you'd be driven enough to at least do some basic research yourself before asking to have the info spoonfed to you.
Old Oct 20, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
^ He is right, but anyways, open wide! lower end will fit if you use the d16 oil pump and block off the dipstick tube, you end up destroking the motor back down to 1.6 ltrs. I think the valves are the same, springs will definely work. cam wont work. Im not sure about the cam gear. We can get all D17 kindsa stuff than has been extensively tested by crower, right down to custom cranks and all, why try to reinvent the wheel???
Old Oct 20, 2005
turboengnr's Avatar
DONT PANIC
dot forget about the transmission. The d16 tranny bolts up, you just need to build a custom shifter and linkage. And im not sure if the stock axels are the same splines and diameter as the D16 one.
Old Oct 20, 2005
Spoolin's Avatar
spoolin by you
what about the cam gear? anyone know about that?
Old Oct 20, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
i dont think it will work.
Old Oct 20, 2005
Draven2's Avatar
small cities make me poop my pants
Draven2 is a jewel in the roughDraven2 is a jewel in the roughDraven2 is a jewel in the rough
Thumbs down
Wah Wah Wah!! Get over it...
Old Oct 20, 2005
djmota's Avatar
cam gear wont work.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
MiniMi
May 27, 2015 01:57 PM
Paul Harsze
May 20, 2015 11:37 AM
lienhart88
May 19, 2015 08:48 PM
SoyerOner
May 11, 2015 09:46 PM
