Steering wheel question
Old Oct 3, 2005
TheSmuggler's Avatar
Well, sorry that this is stupid, but I've been wondering... I've never sat in an EP3, and was wondering about the size of the steering wheel. Is it the same size as the RSX, or ours, or is it in between?
Old Oct 3, 2005
Transformer_Guy's Avatar
Lost in the Matrix
Transformer_Guy is on a distinguished road
Same size as a S2k
Old Oct 4, 2005
ok well you got me there, how does it compare to the RSX wheel and ours, because I can remmeber what size those are lol.
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
the EP3 wheel is smaller in diameter than ours but has a thicker ring. I had the EP3 wheel in my EM2 and it was a really nice change for sure.
Old Oct 4, 2005
Ahhhh, so it's smaller than ours, but is it larger or the same size as the RSX one. I'm just wondering b/c I would hate to change it out, and then think it looks to small and stupid, or if I couldent see the gauges propery through it...
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
here's mine...it didn't look small...it looked awsome. You can see a little more of the top of the speedo when its all the way down compared to the OEM wheel but none of them will be perfect. Telly has the RSX wheel in his EL if you're interested in seeing that as well but it's the same size.
Old Oct 4, 2005
*bows to pharoh* Thanks a bunch man, I really appreciate it. It actually dosen't look bad. and I'm asuming you didn't have an airbag problems usuing that usdm wheel right?
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
none at all. just some advice....wire the switches from the OEM wheel to your EP3 wheel....much easier. they'll bolt right up to the same position on the wheel.
Old Oct 4, 2005
Hmmmm is the H emblem on that si wheel the same as our H? lol
Old Oct 4, 2005
Hmmm wire the switches? What do you mean? Since they are both dual stage shouldn't you be able to just unplug out of ours and replug into the Si one? Also, may I ask where you got yours?
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
yeah more or less..lol.
Old Oct 4, 2005
Ok,. last question I promise!!! lol. I see yours has red stiching. Now did that come on all ep3 wheels, even our usdm ones?
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
no the UK switch is different and altough I think the wires are the same color (lol) you can't use them...different gauge.
So....unplug the Si switches and remove them from the wheel.
then...plug in the switches from your OEM and connect them to your OEM wheel and bolt it up.....it'll fit perfect.
Old Oct 4, 2005
Pharoh's Avatar
Bobaganoosh!
all of them...there is no USDM...it's all UK I beleive but yes...all red stictching
Old Oct 4, 2005
Alllrighty, thanks alot bro, I appreciate it =)
honda200192
Suspension
Oct 27, 2019 12:23 PM
honda200192
May 31, 2015 05:57 PM
Optimus34
May 25, 2015 11:52 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
