Need Feedback on product
Old Jun 20, 2005
Michalo187's Avatar
Abortion Survivor
Who has those eibach anti sway bars and how good do they work??? How hard are they to install and do you guys think they are worth it?
Old Jun 21, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Talking
i have the neuspeed rear sway bar and it made i dig difference in handeling ect plus it has tie support.
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
how much do those run for?
Old Jun 21, 2005
got mine for $308.16 from ultrarev.com Yes it's more expensive You can get front and rear Eibach for $306.96 but you getting smaller bars and no rear tie support. The rear neuspeed is 22mm the eibach is 16mm. The bigger size will help. In my oppinion NEUSPEED is the best co out their making suspension part's for our car's.
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
how hard is install
Old Jun 21, 2005
Pretty easy as long as you grind a taper on the lower controll arm bolt's you'll notice that the factory bolts have a taper on them allready the neuspeed bolt's do not. I fought trying to get the controll arm lined up for hrs no good ground a taper on them put them in as far as they would go hit them with a hammer and all good.
Old Jun 21, 2005
Michalo187's Avatar
Abortion Survivor
Thanks so you suggest these over eibach??
Old Jun 21, 2005
ya defentally i have an progress technology 27mm tront sway bar and a 22mm neuspeed rear sway bar. Eibach's sway bar are smaller in diameter. as long as you go bigger than stock you will notice a big difference.
Old Jun 21, 2005
as long as you have the right tools and you grind that taper on the controll arm bolts like i said you'll have no problems.
Old Jul 8, 2005
IronFist's Avatar
Don't get too big, tho. The front and rear sway bars need to be a certain proportion to each other or your car will understeer/oversteer.
In other words, if you keep the stock front one, you could increase be rear one to I think 22mm or something (whatever the RSX one is, because it fits perfectly). But I think if you were to keep the front stock one and increase the rear one much more than 22mm, you would mess up your handling unless you were to increase the front one as well.
Old Jul 8, 2005
IronFist's Avatar
Ask in the suspension forum. They know all this stuff.
Old Jul 8, 2005
eyegiant's Avatar
eyegiant is an unknown quantity at this point
I would go with progress, much cheaper and handles as good, that's what I have on mine.
Old Jul 8, 2005
Michalo187's Avatar
Abortion Survivor
I will probably invest in some really soon want my car to handle a little better
Old Jul 12, 2005
Talking
i have 27 mm progress front and 22 mm neuspeed rear have had no problem's.
Tyler93
Detailing
Oct 24, 2015 09:48 PM
carid
Sep 28, 2015 10:13 AM
kevfarr
Sep 18, 2015 02:28 PM
