dual exhaust 4 the vic
Old Jun 12, 2005
  #31
Michalo187's Avatar
Abortion Survivor
you know now that i think if it if you make the exhaust small enough then it shouldn't effect the performance any because it flows the same if you put huge *** 2.5 then yeah even single will hurt it
Old Jun 12, 2005
  #32
MajinB's Avatar
Drunken Master-7thgen Ninja
Originally Posted by 01redJDM
no!! 10 tips would look better
i'm sorry i meant to say that it had 4 or 5 INCH wide tips. my fault. will be clearer next time.
Old Jun 12, 2005
  #33
cambo's Avatar
I wish I was asian
4 or 5 inch tips still look horrible.
Did they say Folgers on them also?
Old Jun 13, 2005
  #34
MajinB's Avatar
http://www.7thgencivic.com/forums/sh...t=39902&page=3
others are discussing this. maybe 5 inch would look bad but 3 inch pipes would be fine.
Old Jun 13, 2005
  #35
S2000man01's Avatar
O RLY
Originally Posted by QBoi
I've read that if you single out the exhaust on the s2k, you gain some performance
the exhaust gains between the single and the duals are quite similar.
Old Jun 13, 2005
  #36
S2000man01's Avatar
O RLY
Originally Posted by scansel912
If you've got 2 separate exhaust manifolds it makes sense to have to separate exhaust pipes. If you have one exhaust manifold collects into one pipe (Like ours) it doesnt' make sense to split it back up again.
FYI many cars that have V6 or V8 engines have two exhaust manifolds that come together to one pipe at some point or another, and THEN break back off to a dual exhaust.
Old Jun 13, 2005
  #37
S2000man01's Avatar
O RLY
either way, having duals on the civic is probably not going to look good. it just screams rice. particularly because the engine doesn't require that kind of cfm/backpressure for the engine.
and yes the S2000 does have a true working dual exhaust. and no, single tips don't necessarily provide more power for it. it all comes down to the backpressure created and the CFM provided. there are duals out there that give just as much gain as the singles for the S2000.
and again, many cars that have dual exhaust and V-configuration engines all come to one pipe at some point (i think it has to do with emissions and the O2 sensor/ODB II sensor) and then split back again to the dual exhaust.
Old Jun 13, 2005
  #38
zachgeyer's Avatar
lose bak pressure Search
Old Jun 13, 2005
  #39
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
here is my dual..it is a ractive axle back with a custom 2 1/2 hooking up to that, imo it was the best sounding exhaust that I have herd on a civic. But my bodykit was set up for it and I was going show...plus before anyone calls me a ricer I had a turbo so I didn't lose power..truthfully I got this exhaust setup 3-4 days beofre I put my turbo on and it sounds a whole lot better with turbo, no pingy or raspiness, low down growl when at wot and you can still whisper to your gf in the passenger seat at highway speeds...I loved it
Old Jun 13, 2005
  #40
S2000man01's Avatar
O RLY
having the body kit set up for it, and having that exhaust, I must say that looks good. unfortunately many will not look at the "show" aspect and will call it rice since it likely hurts performance.
Old Jun 13, 2005
  #41
MajinB's Avatar
hey Civic type S. who made that exhuast. thats exactly what i wanna put on my car. exactly. how big are the pipe tips? anyway. yeah looks cool as shiatsu.
Old Jun 13, 2005
  #42
joelwastaken's Avatar
joelwastaken is an unknown quantity at this point
holy **** that looks ****in tight man
ya pretty much exactly what i want on the back of my civ cept i want mine a little smaller
Old Jun 13, 2005
  #43
it is made by RACTIVE yeah I was scared as hell to put it on my car at first thinking it would sound like a$$ but it was awesome..you will not be dissapointed, sorry for the bad pic I will have to see if I can find a better one, anyhow the tips on the pipes are about 3 - 3 1/2 wide, it didn't look big at all. I paid 469 for the rear section..kind of price that the custom cat to the axle was 165 so it was an expensive set up to say the least
Old Jun 13, 2005
  #44
MajinB's Avatar
ok see 3 to 3.5 wide is perfect and it looks sooooooooooooo cool. so how much was it total? RACTIVE huh? ok so is it cat back or axle back. a little confused. you bought a custom pipe from the cat to the axle? then you had those two pipes put on? help me out here. sorry bout the confusion.
Old Jun 13, 2005
  #45
it is a ractive AXLEBACK system, I went to my local muffler shop and had a 2 1/2 inch pipe made from the cat to the axle...making it a cat back basically
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Mannimarco
Sep 7, 2015 10:01 PM
