Kamikaze Header Help
Old Jun 4, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
started to install my kamikaze header on my 03 ex sedan, took off factory manifold. got the kamikaze header in place only to find out it wilkl not fit into place. It's hitting the alternator and the ac lines. Is their any 1 else out their that has my car and installed this header ? Need Help Please
Old Jun 4, 2005
strange. Mine went right in. can you post a pic of where you're having trouble? Did they send you the wrong one or what. The ex is just the top part with the four tubes.
Old Jun 4, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
you probly have the lx/dx header, the ex is only the top, theres no way anything could get in the way.
Old Jun 4, 2005
heres the part number HCH15008C i don't know how to post picks, and i put it back together.
Old Jun 4, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
wow thats a nice header. I want one.
Old Jun 4, 2005
it gives more performance than the generic or dc sports header too. Good mid range. But thats the right part number. I don't know? You could unscrew and move the lines if they're in the way. Just look for the bolts.
Old Jun 4, 2005
Why is this pick so big, How do i resize it.
I figured out what the problem was, I loosened the ac line bracket and moved it out of the way, and found that theirs a little plastic box on the top of the alternator i removed the off the backet and the header went right inplace like butter.
Old Jun 4, 2005
you just have to loosen some bolts and move it over. Just move it slowly. Nothing should break. It shouldn't be that far over.
Old Jun 4, 2005
Hayz's Avatar
^^agreed... that doesn't look right?! maybe it's just me...
Old Jun 4, 2005
2K1Civic17"Gabe's Avatar
Looks like the fitment of my TSI turbo manifold, haha. I was gonna say, time to bust out the dremel and start shaving for a couple hours, hehe.. Glad you got it on.
Old Jun 4, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
had no prob with mine, except for snapping the two top bolts thanks to a piece of **** torque wrench. Someday I'll get them fixed. My mechanic said it's not leaking and I've been running like that for months now.
Old Jun 4, 2005
Redline04's Avatar
Is that the ceramic finish you guys have?
Old Jun 4, 2005
yah hi luster caramic Don't worry your new one will fade to silver and won't be shiny in a few months.
Old Jun 4, 2005
i got it fixed once i figured out what was wrong. Should i use the gasket that was on the factory manifold or get a new one ? Whats the torque value of the 2 bolt's and 3 nut's. Will i notice any increases ?
Old Jun 4, 2005
i noticed a difference compared to generic ebay header I had. You should use a new gasket because it seals with heat. I reused mine and now its leaking a little. I believe those bolts are only 18ft/lbs or something. Just do em tight but not too tight. Little more than spark pluigs.
Old Jun 4, 2005
paradoxblue's Avatar
yeah the old gasket will form to the nicks and runs in the header it as on.. once u switch it may not reform then it will leak like a siv
Old Jun 4, 2005
scizod's Avatar
scizod is an unknown quantity at this point
quick question.....
What else would I need with the kamikaze header. Did it come with a downpipe? I have a 03 ex coupe automatic. Can someone tell me the web site for Kamikaze. I want to get the kamikaze header with downpipe and highflow cat. Is that what I need or does the header come with a downpipe? Thanks
Old Jun 4, 2005
The haeder does not come with a down pipe or high flow cat just the header. I ordered mine from mmrusa.com it took ab 6 weeks for the date i placed the order. As for a new down pipe and high flow cat, megan makes a down pipe for our car's but it has a resignator insted of a cat. I sugest Random Technology cat that's what i'm getting, they make 1 sepcally for our car but i donn if it comes with a down pipe. I decided to go with a custom exhaust 2 1/4 stainless randon tech cat and apexi n1 muffler. buy the way if you order the header and for some reason you decide you don't want it you can't return it they have a no return policy.
http://www.kamikazeperformance.com/s...hop/index.html
Old Jun 4, 2005
Hayz's Avatar
I've had mine for over a year still shines like new
Old Jun 4, 2005
where should i get that gasket from, my honda dealer or an auto part's store ?
Old Jun 4, 2005
Hayz's Avatar
I got mine here http://www.hondaautomotiveparts.com/...OLD+%28SOHC%29
370505 002 1 Gasket, Ex. Manifold (nippon Leakless) $3.16
Old Jun 4, 2005
honda dealer for gasket. I got my header from www.bigjoshracing.com
Old Jun 4, 2005
Hayz's Avatar
same here ^^^ www.Bigjoshracing.com
Old Jun 4, 2005
so to the first poster, did you feel any gains from it?
Old Jun 5, 2005
scizod's Avatar
Stupid question but does the down pipe bolt up directly to the catback exhaust or do I have to order a cat. I have a Tenabe Hyper Super Medalion. Does the megan downpipe bolt up directly to the header or is there modifications needed.
Old Jun 5, 2005
i think it will bolt directly to the header but it does not have a cat. i kinda need the gasket right now gotta go to work tmr night i need to get my car back up and running
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
