Exedy clutch?
Old May 10, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
Exedy clutch?
Do any of the aftermarket clutches require a flywheel from earlier civics, like 212mm from a 1.6L. I just wanna make sure becuase i seem to be reading that everywhere, but shops are telling me i don't. I am mainly refering to the exedy clutch kit, but i wouldnt mind knowing about act or clutch master either. Thanks
Old May 10, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
No, you can use the stock flywheel.
Old May 11, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
just make sure you get your flywheel resurfaced.
Old May 12, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
i'm changing my clutch, i was thinking ab a stage 2 clutchmasters clutch and a Fidanza aluminum fly wheel. What do you think?
Old May 12, 2005
Super Member
i was told that exedy makes groves in its clutch kits in order to make you use another flywheel. Dunno if it is true but that is what the guy at robear racing told me. O well i decided to get the act stage 1, stay with my stock flywheel and hopefully everything will be ok.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
Klame9420
Sep 7, 2015 10:03 PM
