VP Header Help!
Old May 3, 2005
High_OctaneZ's Avatar
High_OctaneZ is an unknown quantity at this point
Exclamation VP Header Help!
I Have a 05 vp the converter is located right at the stock header.I was wondering what an aftermarket exaust would do about this? Does it relocate the converter and extend the o2 wires?
Old May 3, 2005
rockindavp's Avatar
rockindavp is an unknown quantity at this point
Yes, an aftermarket system will move the cat to the downpipe I believe. As far as the O2 wires, I have heard that no real mods are needed at all. However you will need to buy an EX header and downpipe, then you can pretty much choose from any aftermarket catback system for the EX. Nobody really makes anything for the VP these days
Old May 3, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Your cat and the manifold are all one piece. In order to eliminate this setup, you will have to go with an aftermarket header and aftermarket cat specifically for the VP/DX/LX.
What I looked at doing was using an Ex Header (stock or aftermarket), Mid Pipe(EX only), Cat(EX only) and then you could use an EX Catback Exhaust.
Up to you though, and you may want to search in the Tech Section about this before you get moved or a threadlock.
And if you have any questions about your 05 VP, just PM me, I drive an 04 VP.
Old May 3, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
buy a header for an ex, high flow cat(test pipe) for ex, and a cat-back for an ex and it will work. and BTW, the mid pipe and cat are the in the same unit. there's only 3 pieces to the exhaust. header, cat/downpipe(all one thing), cat-back. there's no 4th peice.
Old May 3, 2005
LiKEaFeRiO's Avatar
VP/LX/DX also has 2 o2 sensors while the EX has one.
Old May 3, 2005
bradmanuwf's Avatar
no, the ex's have two. I know cause I have an ex...lol
Old May 3, 2005
Thx for the help
Old May 4, 2005
bradmanuwf's Avatar
np dude
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
