Random Technology Cat
Old Apr 18, 2005
DEcivic01's Avatar
Just look for the Civic that was attacked by shopping carts
DEcivic01 is an unknown quantity at this point
I just installed my new cat from Random Technology the other day and ran into a problem. The cat also includes the downpipe (b-pipe so says honda) welded to the cat just like the stock one. The problem is that the cat was designed to work with a stock cat back exhaust. When it is bolted on with an aftermarket cat back with larger diameter piping, it causes the midpipe to come in contact with the undercarriage. Big problem. It makes the loudest racket I've every heard. I'm yet to figure out how to fix it short of stuffing something heat resistant in between the midpipe and the undercarriage. Just thought people considering the cat should know.
Old Apr 18, 2005
sasquatch's Avatar
sasquatch is an unknown quantity at this point
I do believe the random techs come in different I/O diameters...sounds like you got the wrong one for your application.
Old Apr 18, 2005
DEcivic01's Avatar
I don't know. They only had one listed for the 01 EX. I'll have to look into that.
Old Apr 18, 2005
CapYoda's Avatar
Escaped Convict
no u got the right one. its just could have been designed better.
this isnt like most random tech cat convertors.. this one is designed to fit our civics (ex, vtec, d17a2 models)
since our cat convertor is welded onto the stock downpipe/b-pipe..
I think other people that have experienced the problem have solved it by putting, as you suggested, heat resistance material between the underbody and pipes, or bend the hanging hooks on the pipes to give more clearance.
I dont have too much experience with it though.. what I'll suggest is do a search on this.. or just take it to an exhaust shop and have them fix the problem for you..
Old Apr 19, 2005
djmota's Avatar
remove the aluminum heat shield and youmay have to bend the corners of the cat with some pliers to get it to clear. also you may have to adjust some hangers to get everything to sit where you want. its pretty common with that cat.
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
blizza
Sep 20, 2015 04:09 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
