Unorthodox Racing
Old Jan 8, 2002
KOPSEAL's Avatar
KOPSEAL is an unknown quantity at this point
Unorthodox Racing
Hey guys I checked the site at Unorthodox racing and they have a list of performance pullies coming out for the 1.7 2001 civic and up and they have a 3 peice set includes the crank and 2 others for 349
and availablitity is TBA but check out the site and stay tuned. I think we will see some power out of these babys'. Later
Old Jan 8, 2002
kimpislx's Avatar
kimpislx is an unknown quantity at this point
Cool let us know any updates.
Old Jan 8, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
Right On....I hit that site everyday waiting to see when the Ultra SS Set comes out (the set with all 3)
Old Jan 8, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
does putting the pulley's really make a difference?what about aem ?
Old Jan 8, 2002
antidote11's Avatar
Pulleys make a difference !! The AEM pulleys are great, they are just the accessory pulleys though. The Unortho kit comes with those and a crank shaft pulley. The crank shaft pulley is what gives you the most power gain. They claim to get you from 8 - 15 HP. IMO, I would think on a moderately modified car, it will probably get you from 6-9 HP or so, but I could be wrong !!
Old Jan 8, 2002
CivicEX2k1's Avatar
CivicEX2k1 is an unknown quantity at this point
<< does putting the pulley's really make a difference?what about aem ? >>
yeah, it makes ur engine work less on making sure ur acessories work and focuses more on making ur tires spin.
Old Jan 8, 2002
2k2civic's Avatar
These are underdrive pulleys right?
Old Jan 8, 2002
nongv's Avatar
nongv is an unknown quantity at this point
wouldn't it mess up your timeing?
Old Jan 18, 2002
01rallyeredex's Avatar
01rallyeredex is an unknown quantity at this point
I heard that if u have a subs and a amp in you're car and you get the pulleykit that the alternator can't put out enought power to supply the amp and everything else in the car. Is that ture?
Old Jan 19, 2002
1028CiViC's Avatar
it's not good if you have subs and amp..cause you are not going to get enough batterie..
the car might not start..so if you plan to get subs.don't get pulleys..get cam gear..
and is it worth to get.. hm..aem better or unorthdox? and price range.?
Old Jan 19, 2002
Bartkat's Avatar
AEM lists the Tru Power Pulleys for 2K1 Civicx for $150. Do they really have these? They also warn against high powered stereos with the pulleys.
AEM TRU POWER
Old Jan 19, 2002
1028CiViC's Avatar
i wanna get these~
krazykoncepts
Sep 8, 2015 09:02 PM
